Is bulldozer going to be AM3 compatible?
I suddenly find myself seriously considering jumping ship and going AMD for a while. :D
yup bulldozer will be am3 compatible.. hop on over :D
A lot of people said that slapping an extra 2 cores will limit the overclocking to these X6 CPU's, but the reviews proved that a 4Ghz and over on air is possible. Very impressive from AMD.
Reserved.
Is there is any review talking about how the Turbo will behave with an overclocked system "say 4GHZ" and how will it affect stability
Wish someone would actually talk about AM2+ DDR2 motherboard support. Everyone is soo mealy-mouthed about what these cpus will and will not just drop into its infuriating.
And before someone yells just get a new AM3 motherboard remember; the 1055t is a $200 processor, even after years of price cuts by AMD thats still chump change in the world of high performance CPU's! Easily worth every penny to upgrade from an old stodgy Phenom.
I just finished Anand's article and it was lacking a bit...
Which one is showing results of memory overclocking? How high new NB can push DDR3?
I will read more reviews @work (if possible) but I can't still buy one in UK :(
Most reviews about overclocked Phenom II processors never even bother overclocking the NB, which is a shame.
From hardwarecanucks
Due to severe time constraints we won't be wow'ing you with our extensive overclocking endeavours, but here is a teaser for an overclocking article that will be posted next Monday:
http://www.hardwarecanucks.com/forum...review-16.htmlQuote:
In the follow-up article, we will be testing various things like max stable bus speed, max stable northbridge frequency, and max stable memory frequency. Also, since this is a question that we have seen asked over & over, we will be comparing Phenom II X6 overclocking on both AMD 790-series and 890-series chipset motherboards.
I just looked at Anandtech and xbitlabs review, and I've noticed that i7 860 outperformed 1090T in majority of benchmarks.
Overclocking article at HWBOT: http://hwbot.org/article/news/hwbot_...rature_scaling
excellent toys to play with (x6 + AM3 board) :)
The 1090T does put on a good show :) very good processor and better than i7 930 in most tests.
Did u all see this
http://media.bestofmicro.com/E/K/245...onsumption.png
+1
Very interesting about how well this can be OCed in 45nm ....
you can add the excelent review of hardware.fr
http://www.hardware.fr/articles/789-...90t-1055t.html
The reviews I've seen show i7 930 and 860 performing better in most tests
So far, Ive looked at anandtech, techspot and xbitlabs
At what reviews did you look ? Maybe we looked at different reviews
Good power consumption at idle. At full load it consume much more power than Intel Lynnfield processorsQuote:
EDIT: Did you look at this ?
http://images.anandtech.com/graphs/a...1918/22637.png
Guru3d and Tom's Hardware pretty much shows the 1090T beating the i7 930 in most benchmarks
fark a review I say, I only look at overclocked results anyhow ;)
Check out the Hexus review as well, pretty good comparisons.
Just a side note:
AMD's L3 cache contains all the L2 caches of the cores right? So with six cores you lose 3MB of your L3 cache, leaving only 3MB left? As with a quadcore you would have 4MB left.
This might be some explanation to why it performance should be less in single threaded apps (and offcourse the same memory bandwidth then a quadcore)
In progress: http://www.lilireviews.com/amd-phenom-ii-x6-1090t/
It's portuguese :up:
Lost Circuit tests show AMD 1090T now hold worlds fastest title for stock bench of MainConcept H264 encoding by screaming past every desktop Intel CPU in the marketplace.
http://i364.photobucket.com/albums/o...coderbench.gif
Add also second place in important 3D Studio Max 2010 bench --
http://i364.photobucket.com/albums/o...x2010bench.jpg
For games, Overclock3D shows high performance in games and minimum frame rate of AMD 1090T in Crysis is three times i930 !
http://i364.photobucket.com/albums/o...ck3dbench1.jpg
