George, if you tighten tRCD to 6 what speed can you hit Prime stable?
It doesn't matter, both kits have a low price in South Africa and might just make a nice 24/7 kit ;)
For me it's 6-6-6-x :D If you could test, say, DDR1500 6-6-6 it'd be greatly appreciated ;)
Ok I'll try for some MemTest action @ 6-6-6 @ 1.68V ;)
DDR3-2300 on air @ 1.7V done on the Classified E760 and an i7 980X Q4EG.
Screenshots, and more tests coming later on.
And triple channel DDR3-2400 on air done :D
Gotta go now, but I'll be back later on with benchmarks at 2400 or higher ;)
What timings did you need for that?
Was actually trying to test the 980X's memory controller, so I started with really really loose timings :D ( 11-11-11-31 ), but gave them a quick test at 9-11-9-30 and it passed a few #5 loops ( 2 or 3 ) before I shut it down and left the room :p:
these are on sale for 169$ in frys. are they worth buying?
For 169$ I'd say yes, it's a bargain.
Not the best solution if you are a benchmarker, but for a normal user/gamer it's more than adequate.
