Good question Jack ;) = The piece I had wasn't long enough. :D I will take that into consideration on my next build. Thanks for the tip.
And one other Q, why didn't you put the captube right into the evap?
Jack -
I slide the cap tube into the 1/4 tubing until it hits the inside of the evap. Then I back it out about 1/8 inch.
It is 1000 times easier to do it this way. Also if you ever want to change the cap tube, it is very easy to take out.
If you just stick the cap tube into the evap and then braze everything at once it is easy to melt, brake, damage the cap tube.
Exactly Reed :up:
Nice performance Ron!!!
I braze the evaporator together with the stub for suction (5/16) and the stub for cap tube (1/4) inserted. I purge while I braze. Then when I'm finished I can clean it and lap it easily. After that I add the suction line and cap tube. It doesn't take much heat for these two so I don't have to worry about melting alloy on already brazed evap. Now I can pressure test.
When I put the cap tube in I pinch the 1/4 tube to hold the cap tube snuggly so it doesn't slide in or out.
Okay :up: I gotta get this out the door. I had to get the fuel pump replaced in my truck so I've been running behind the last two days. Can't get much done walking. :)
http://www.under-the-ice.com/teampus...0camo_01SS.jpg
http://www.under-the-ice.com/teampus...0camo_02SS.jpg
http://www.under-the-ice.com/teampus...0camo_03SS.jpg
http://www.under-the-ice.com/teampus...0camo_04SS.jpg
http://www.under-the-ice.com/teampus...0camo_05SS.jpg
http://www.under-the-ice.com/teampus...0camo_06SS.jpg
http://www.under-the-ice.com/teampus...0camo_07SS.jpg
http://www.under-the-ice.com/teampus...0camo_08SS.jpg
on/off button place = WIN :D
Hey Ron you missed a place with the paint and the insulation :)
J/K
Very nice work!!!
In-sane quality, mr.Ron! :up:
wow that is a sweet unit, hmmmmmmmmmm kinda looks just like the one i gots me here :surf:
Top nOtch work!
wish i had one of your units man! :up:
Reall nice unit!
Kind Regards
Nice looking package there Ron , clean !
Again another sweet looking unit there Ron :clap:
All your other pic's are missing in past posts for this thread , can't see them anymore here, just the little box with a red X?
Thats a beauty of SS , very nice Ron , your builts keep looking better and better every time :clap:
Thanks Bill - don't know where the pictures went. I move some stuff from one server to another and I must have screwed up links. bahhh :mad:
Thank you Chispy. :) I noticed your selling off a lot of stuff. Are you getting out of the business or cleaning the closet? :D
Very tidy, indeed, welldone - but where is the thermocouple ?
