Here we go found the Asrock cache for the Asrock 890FX
http://webcache.googleusercontent.co...&ct=clnk&gl=uk
I`m aiming at Asus Crosshair Formula IV. Two PCI ports which I need, for Wi-Fi and sound card. I`ll sacrifice one GPU PCI-E instead of PCI-E x1. Probably 100$ cheaper than Extreme version. Hope it`ll be good :D
http://www.orbitmicro.com/global/ris...-c-33_898.html
there still other solutions to that problem. not like your going to more then
will finally be upgrading to ddr3 then lol been waiting ages for these 890FX.
I hope there is an 890FX Micro Atx in all of this. ASUS Crosshair IV Gene would be cool.
Anyone know something about Boards from DFI ?
can a big pci-x16 be used to put in a pci-X1 (small) card ?
What are the chances for TRIM raid support on 890fx platform ?
I'm currently running 2 intel ssd in raid 0 and was awaiting intel to support it , but now i'm moving to amd platform ... I'm curious . Is it 0.0000 ?
Intel doesn't have it either. It was all a misunderstanding because of the wording in the readme file for that driver.
Link: http://www.xtremesystems.org/forums/...4&postcount=63
I think they all have a nice appearence, and am anxious to see how they perform. Im definitely liking the Crosshair IV Extreme, and it just may be my next board.
...aside from the IGP what is the Major difference/ performance to the GX series & 870 series?
confirmed 335 htt on one of those...worked on it for a while last evening, but would not go past that number....but 335 is awesome by itself and for all those getting non BE 6 cores, that goes a long way in OC'ing.
any chance to see how is asrock performing in oc? are we have someone from asrock or that is close to that company?
@prznar1
they have a Fan page on FB
you ask & post your queries there & someone directly from ASrock will answer you.
i would prefer Crosshair IV Series
but my Crosshair III is very new!!! i will use it for more time
http://img693.imageshack.us/img693/2...1227363d06.png
Range of prices for these motherboards?
S4lu2!.-
