http://www.youtube.com/watch?v=RSOJucZwe7I
what do u think of the RV02 case ?
and anything less than 400 dollars
just type me a list :)
damn im going over my 2700 dollar limit
i think its a good idea to start with 2 cards then 3 cards dont u think
Personally I would go with 2 cards right now 3-way sli doesn't scale that well unless your benchmarking. 2-way will run great for any modern day game. Plus you can spend your extra money on a beefy psu and add another card later. Who knows maybe by the time games out grow your rig the next gen of cards will be out. What are you intentions with this rig? Crunching? Folding? Benchmarking? Gaming? Also cpu setup?
F this
gona buy two 360 rads :rofl:
gona buy a lian li PC-A71F enough room for 2 rads on top of each other
or maybe ill just get a BlackICE GTX Xtreme
just think...you wont need to heat your room in the winter time with that much wattage being burned by your computer :D thats as much as most electric space heaters!
btw silverstone TJ-07 or almost any mountain mods case would both be perfect for a twin power supply setup with enough room for 3 to 4 large cards plus liquid cooling all internal.
dare I ask what game needs 3 GTX 480's?
my triple 8800GTX's run battlefield bad company 2 @ 1920x1080@60hz 16xQ AA supersampling, 16x AF, vsync, with everything on highest settings and smooth as silk frame rates. (haven't checked actual FPS but it looks like 60+fps it does not stutter at all)
tpq-1200 ftw
1920х1080 is so last century :ROTF: Seriously though, most people are buying multiple 5870s or 480s for multi-monitor gaming with vast resolutions which might exceed yours by the factor of 3-6 times (imagine triple 30" gaming ;) )
Also, did you see how much power 2033 sucks up in DX11 mode? even on a single 30", you may need triple 480s to turn all the eye candy to the max.
I used to have that case it is massive and sleek, great choice!
what do u mean "used" what do u have now ? and why
:) i flooded the liquid cooling section with questions
too bad it turns out coolant/dyes has a problem under heat because the dye separates and creates a disaster for the blocks
+ tubes that are UV reactive arnt that powerful
this is a far dream :(
http://s10.directupload.net/images/090211/nsk6qma4.jpg
Well I still have it in my garage unused at the moment. Didn't have room for four 120.4 rads...lol
it does
on top .....
if its still there can u check for me
http://i44.tinypic.com/214avm9.jpg
I meant FOUR 120.4 rads lol huge watercooling setup over here. Just measured it will fit but your going to have to take off the top input ports.
inputports?! , WE DONT NEED NO STINKEN INPUTPORTS
from treasure of the sierra madre if u didnt know xD
BADGES
Corsair TX850 here...kinda toasty with GTX 480 SLI oc'd:D
For benching with 6Ghz+ I use Zippy 850W + Corsair TX850W
when i get home from this trip I plan to build a 4-way just for giggles ;) Might have to have a a second PSU hole laser-cut in my case though.
With the gerls on my case?
http://img138.imageshack.us/img138/7985/dsc02203o.jpg
http://img651.imageshack.us/img651/4598/dsc02202j.jpg
wow.........
for some reason this reminds me of Bladerunner
I ordered 2 Strider 1000-P PSU's for my build. I have a Mountain Mods Case so plenty of room for the PSU's and three 360 rads.
Just waiting on eVGA to release the FTW cards for multiple qty. Only let me pre-order 1 card, so I might have to just buy the SC version and thro EK WB's on them to get a 4 way sli
