Hmmm well Im glad I haven't bought a videocard yet, may need to get a new motherboard if these lists hold up.
Gigabytes list is far from updated, I just picked a random board that's not on the list but it supports X6 anyway.
I think Gigabyte will do their job, given their recent history of updating BIOS for old AM2 boards from 2006 to make them AM3 compatible.
I don't see why the 790X-UD4P is not supporting it when some of the 785 and even 770 boards are getting bioses for them. I hope they give me F10 bios with 6core support and ACC fix as well.
Just be patient people...the boards that do support will indeed support, it may be just a matter of time for all these boards to have the updates implemented into their BIOS.
It's still very early people. I am sure mobo manufacturer's will include Thuban support on most of the high end boards. Just give them time.
Perhaps you didn't look at the third page of the compatibility list?
http://www.gigabyte.com.tw/Support/M...M3_1454&Page=3
I see the board you linked right there. :p:
Biostar TA890GXE supports X6 processors.
http://www.biostar.cn/app/en-us/t-se...t.php?S_ID=467
MSI 890GXM-G65 supports X6 processors
http://www.msi.com/index.php?func=pr...2&maincat_no=1
more or less my main idea was to make sure people knew that their boards would be compatible, and what bios is needed. i would hope any 8xx series boards would be compatible, otherwise the board must have been a complete failure. so its really about older ones, AM2+ or AM3, just as long is the good old faithful ones we have been using for 6 months or even over 2 years.
Looks like ASUS Skipped M3A79-T Deluxe from support list
Even the "old" nforce board like M3N78-VM and M2N68-AM SE2
got BIOS update to support Phenom II x6
(M3N78-VM don't have a "M4N" upgrade as M4N78-VM isn't the same spec as M3N78-VM (lack of feature w/M3N)
I hope they will do their job on this, otherwise i must buy a new board, because my 790xt-ud4p is not there. Although it's strange that low-end boards got the support and the high-end ones still haven't. I'm sure they'll come around..kind of :DQuote:
i wonder if the cheaper boards have them cause their bios is easy to update, while the nicer ones have too many options that still have to work after the updates. i doubt its as simple as a line of code to say "this cpu is this speed" cause if it was that simple, there would be no excuse and every board probably would be updated
I have an M3A79-T Deluxe and a Giga UD4P, neither of which have official support. I am surprised by that because the M3A is older but one of their highest-end AMD boards even still, and the Giga because it's a somewhat high-end AM3 board.
chill people..... gigabyte will provide six core bios for every amd+ board ! and for every am2 board wich have already am3 support (a lot of them in this present; even if they won`t have am3 logo on them);
the same thing asrock will do (and if they are mad enouch will upgrade bios for nf3 based board with agp :)) )
and the others...... sad but don`t put too much hopes (maybe in am2+ boards; but for am2... no way >> UPGRADE)
At ECS site the support list for AMD 6 core processors. http://www.ecs.com.tw/extra/6core/index.html :)
My A780GM-A ultra support them. :):):)
@Manicdan : please update the 1st post
We've been in contact with ASUS about this, the M3A79-T Deluxe will get support along with many others afaik.
They were focusing on full support for M4A-boards now they are working their way down. M3A78-T will get supported according to my contact (since that's what we asked) so I'd find it very odd if M3A79-T wouldn't :shrug:
Maybe you missed the obvious like i did, there are 5 pages, and your model is in the last!:D
Otherwise you could have tried my tip and go to the CPU support site for that model.;)
This is the current list for 1055T support.
Code:Model PCB Phenom II X6 1055T
GA-770T-USB3(rev. 1.0) 1.0 F2
GA-790FXTA-UD5(rev. 1.0) 1.0 F3D
GA-790XTA-UD4(rev. 1.0) 1.0 F3F
GA-790XT-USB3(rev. 1.0) 1.0 F3
GA-890GPA-UD3H(rev. 1.0) 1.0 F4
GA-890XA-UD3(rev. 1.0) 1.0 F2
GA-M52L-S3P(rev. 2.0) 2.0 FB
GA-M68M-S2P(rev. 1.0) 1.0 F2
GA-MA74GM-S2(rev. 4.0) 4.0 FC
GA-MA74GM-S2(rev. 4.1) 4.1 FC
GA-MA74GMT-S2(rev. 1.0) 1.0 F2
GA-MA770-ES3(rev. 1.0) 1.0 F3
GA-MA770T-ES3(rev. 1.0) 1.0 F2
GA-MA770T-UD3(rev. 1.0) 1.0 F3
GA-MA770T-UD3(rev. 1.1) 1.1 F3
GA-MA770T-UD3P(rev. 1.0) 1.0 F6
GA-MA770T-UD3P(rev. 1.1) 1.1 F6
GA-MA770T-US3(rev. 1.0) 1.0 F3A
GA-MA770T-US3(rev. 1.1) 1.1 F3A
GA-MA770-UD3(rev. 2.0) 2.0 FH
GA-MA770-UD3(rev. 2.1) 2.1 FH
GA-MA770-US3(rev. 2.0) 2.0 FH
GA-MA770-US3(rev. 2.1) 2.1 FH
GA-MA785GMT-UD2H(rev. 1.0) 1.0 F6
GA-MA785GMT-UD2H(rev. 1.1) 1.1 F6
GA-MA785GMT-UD2H(rev. 1.3) 1.3 F6
GA-MA785GMT-US2H(rev. 1.0) 1.0 F4
GA-MA785GMT-US2H(rev. 1.1) 1.1 F4
GA-MA785GM-US2H(rev. 1.0) 1.0 F8
GA-MA785GM-US2H(rev. 1.1) 1.1 F8
GA-MA785GM-US2H(rev. 1.3) 1.3 F8
GA-MA785GPMT-UD2H(rev. 1.0) 1.0 F6E
GA-MA785GPMT-UD2H(rev. 1.1) 1.0 F6E
GA-MA785GT-UD3H(rev. 1.0) 1.0 F5
GA-MA785GT-UD3H(rev. 1.1) 1.1 F5
GA-MA785GT-UD3H(rev. 1.3) 1.3 F5
GA-MA78LM-S2(rev. 1.0) 1.0 F7
GA-MA78LM-S2(rev. 1.1) 1.1 F7
GA-MA78LM-S2(rev. 1.3) 1.3 F7
GA-MA78LM-S2H(rev. 1.0) 1.0 F7
GA-MA78LM-S2H(rev. 1.1) 1.1 F7
GA-MA78LM-S2H(rev. 1.3) 1.3 F7
GA-MA78LMT-S2(rev. 1.0) 1.0 F5
GA-MA78LMT-S2(rev. 1.3) 1.3 F5
GA-MA78LMT-US2H(rev. 1.0) 1.0 F4
GA-MA78LMT-US2H(rev. 1.3) 1.3 F4
GA-MA790XT-UD4P(rev. 1.0) 1.0 F8C
Still no support for GA-MA790GP-DS4H :(
Though my GA-MA785GM-US2H does.
I can see it now Mats :up: but at that time it wasn't listed :D
Thanks for the head's up!
M2N68-AM-SE2 works, it's not an unlocker though. Thanks for the links, only board I haven't been able to get it running on is MSi-770 G45, as usual we'll have to rely on beta BIOSes for a while.
This thread needs stickied like.
Both boards will have official BIOS support once the qualification process is completed. I have betas for both that we are testing now.
Just to make one item clear, it is easy throw a tag line in the BIOS and claim support. It is a whole different story to actually qualify the board. The reason some boards might not be "supported" is that they fail the qualification process.
