Originally Posted by
Nuckin_Futs
The 1st thing you will need to increase is the PLL. For a 4.2 and above stable without having to crank up the vcore you will likely need to start around 1.86 to 1.88 but it is not unusual for a 4.2+ to need or want 1.90v PLL. This is a quad and they really do benifit from raised PLL to stable out. 2nd, follow the profile I posted earlier on page 1 as a guide. Use manual voltages where as much as you can, even if set to default.
I also sugest upping the PCI-E bus if to stable out USB stuff especially or onboard sound and USB mouse for starters. Try at least 110 but some need or like 115. Notce the increase in NB/SB cores, they like at least 1.20v and it is not unusual to need 1.30v on NB & 1.35 on SB. I would play with NB/SB PCI-E 1.5v and test with 1.52v for now, lower if stable later. In CPU config, DISABLE everything but HTT for now till you get stable. I honestly dont feel you should need more then 1.35v (in BIOS) for QPI, but some do need or want 1.4 but that has more to do with RAM and timings I think. (somebody can confirm for us).
