Great info Fugger ... thanks for sharing :up:
*goes back to watch muppets purchasing flaky A0 chips on Ebay for $1200*
Thanks, my X5667 also worked just fine, and the mod also worked great for some wPrime runs @ 5.6GHz+ :toast:
I tested B0 and B1 on biostar board, IMC of B0 and B1 are almost the same.
Tpower X58A doesnt have OCP protection ... but need coldbug mod :D
http://www.pt1t.eu/public/X58/Q3VG/T...x_2448_CL8.png
http://www.pt1t.eu/public/X58/Q3VG/9...4500_1_39V.png
This very good details and nice thread
Thank you for sharing Fugger
Thx Fugger!
Fugger, your GTX 260 uses DX11?
GPU Type : NVIDIA GeForce GTX 260
GPU Clocks : Core 680 MHz / RAM 1250 MHz
DirectX Version : 11.0
Hicookie retest with B1 chip and high clocks, seems the k value needs to be changed or another mod is needed.
A0 has stuff disabled in chip unlike the B1 we are using.
Very useful report FUGGER. Thank you :D
keep pushing it
How 'bout OCP issues on the Eclipse SLI? I at least noticed some quite interesting fluctuations when I set VCore to 1.8V with my B1, but I'm not sure if that's just me. Only tested my chip once so far.
hi guys, got an Q3FE here, running this CPU on 4,4 Ghz i need 1,38-1,4V , 1,44 V to get it primestable... Will this CPU die with 1,376 Vcore and 1,29 VTT quickly? On 25°C water so far.
I wait to try the UD9, I pulled the mod.
The board runs fine with X5680, tested to 40x multiple. Q4HH
You pulled the mod? So it wasn't helping? I have not tested w/o....but I've not been very impressed with my UD7 compared to E760....maybe I'll try pulling mine to????? Thanks for the reply bro :up:
Really learned a lot from you!
