I thought Nvidia didn't have driver problems? Because they have a dedicated driver team.:rolleyes:
the WHQL certificate has almost no use.
MS tests the driver but they only test compatability to check if it installs properly on their OS they dont check stability or performance or proper functioning.
Its basicly a company pays MS money for the Windows compatible logo.
Further the WHQL testing takes a week or 2 wich is why Nvidia often releases a Beta after a new game release to quickly fix issues so they dont have to wait a week or 2 before they can launch a WHQL one.
Its one of the reasons why i never understood why ATI stopped releasing Beta drivers and started doing 1 official driver per month.
NVIDIA pulls 196.75 driver amid reports it's frying graphics cards
http://www.engadget.com/2010/03/05/n...-graphics-car/
Feel free to add this link to the OP post.
I noticed that both Furmark and Rivatuner report GPU temps about 24-25C higher than normal. Everest reports the same as previous drivers. Haven't experienced overheating due to water cooling.
thats weird I was thinking my 275 was running a little warm. I have it set to 75% now just because i didnt like the temps from bc2
My cards started to cycle van speeds up then down, it started within 12hrs of installing. I rolled back. The gpus run too hot and are poorly design IMO, all that plastic crap and when you have 2 - 3 in sli its a fooking room heater. Someone needs to design the casing with a brain.
I have experienced this first had not the burnt gpu, but woke up the other morning of using the new drivers. I've been running gpugrid manually set fans to 100% before I went to bed. Came downstairs and no fan noise but computer was on I figured it restarted in the middle of the night and back to default. Go over to computer gpugrid still running, computer did not restart, and gpu fans were completely off on both my gtx295's. Go to check temp cores were sitting at 120C. Way to fail nvidia:down::down::down: Went back into precision and cranked the fans back to 100% and they worked.
This is what you all get for questioning dear leaders decisions.
def a problem w/them. Noticed the second I launched SC2 beta, screen would flicker and the game would constantly crash. Only has happened on SC2 though, playing LoL was fine.
I noticed that my BFG GTs250's fan was oscillating between a higher and lower speed every few seconds after installing the newer drivers. Thought something was screwy. It broke battlefield Vietnam too.....
*shrugs*
I KNEW something was jacked up with these drivers. God I swear what in the hell is going on over at nVidia; they cant seem to get anything right now a days. Wait till semiaccurate gets hold of this lmao :D
Yeah, NVIDIA totally screwed up with these drivers alright, I thought they were buggy and they give me issues as well, and now the fan control does not work, WTF. Way to go NVIDIA, next time, they better test it properly before releasing it to the public. And people say NVIDIA's drivers work better than ATI, but this is unacceptable.
hell to heaven, heaven to hell. :lol:
WARNING! NVIDIA 196.75 drivers can kill your graphics card
GeForce 196.75 WHQL: Up to 30% increase in performance
AC accelero s1 - no worries here :)
Hahaha 196.75 drivers are no longer available for download!
Been useing 196.75 for a while now , no problems , with Crysis Warhead , Just Cause 2 demo , SupCom 2 , AVP.
I got Evga 295 stock , temps and fan rpm same as always i have everest open on second monitor at all times.
Could it be only on specific brands ? :shrug:
ooooh SHOOT! how will my waterblock know when to turn up.... oh right. ha. so people use those stock heatsink thingamajigs ?
I got no problems with this drivers and I use a 8800 GTS 512 (GTS 250 oc level) and the temps are quite normal.
80° at max during BC2 with stock cooler sounds nice, no ?
