If ECS makes another 160 watt board based on 890X/GX I'll try one,last time I had a ECS I had a DURAN 800.
You got me I cant edit now huh.:rofl:
why does AMD always release the integrated graphics(lower end) ones first?like when they released 790GX and then the 790FX Enthusiast boards later?
i dont really see the benefit of getting this board(890gx) over current 790gx, or 785g unless you have a SSD or planning on getting a SSD for usb3.0/sata3
Dual x2 support,3X pci-e slots,onboard HD 4300,display port,and DDR3 1800 support thats not too bad.;)
So, if im not mistaken, the 8series should support IOMMU right ?
Nice HTPC mobo :) finally ps2 is history :clap:
Will the x6's work on the 790fx chipsets (my crosshair iii formula)? Or will they only be supported by 890 (or is it a manufacturer decision; as in its possible with a bios update?)
So that means that Thuban will be near. Good going.
@ Newegg by Monday?:D
thats not what i said or asked.so where the logic there?
im asking why is the GX always released first?is it easier to make?
isnt it almost the same as the FX chipset with out the integratedGFX?just trying to understand what the difference is and why they follow this release
schedule each time?understand?im not saying that they are holding back
products because another isnt ready,ok?
hmm should i upgrade from a 790X...tempting this is
just in time for my next build... finally .... go go go amd :D hopefully those 8 cores desktop amd cpu will fit nicelly in my budget
Well for HTPC no use for ps/2, ps/2 is only good for pro gamers or such, time to move on.
More space for video connection is good IMO.
Should I take back this 790GX hhhmmm.:shrug:
