Thanks for chiming in you all. This board is great and you all are very helpful, which is saying a lot since many are not.
Can someone comment on the molex adapter I ran across ^, or should I use a different adapter for the majority of psu's that come with a 4-pin and 8-pin power? I simply don't see the need in spending $100 extra on a PSU that has the connectors when I'm not even going to come close to using all that power when I can buy a $100 cheaper PSU and a $15 adapter.
Last question is, should I go with ecc 1066 vs 1333? I'm not sure the price difference is that drastic, but if it saves $100 might be worth it.
