Construction video links are dead :(
couple of questions, hopefully these have been out there a little while now and some people have experience with them.
1. Was there ever an answer to the black front panel instead of the silver one question ?
2. To adjust those flow control screws/nuts whatever, to redirect the water flow, i assume you have to remove the front - two questions regarding this
a) Does it go back together easier/better than the original Aquabox, i've read a couple of threads where people struggled with this.
b) What adjustment position does it come at as standard ? ... all to the front, sides unrestricted or somewhere in the middle ?
3. To use LED's in the Black version, only 2 are possible and you need a screw in plug... correct ?
and finally, what are peoples thoughts ? ... how do they perform, mainly in relation to the question earlier about their ability to trap air bubbles and not let them cycle back into the loop.
Cheers
