mine still says 9.12
the hdmi HDTV support is much better now
UPDATE: uninstalled a 2nd time and removed EVERY ATI registry key i could find, restarted, ran ccleaner and re-downloaded the driver from ati game site and installed, after reboot cat still says 9.12...wtf ati, 4 days before the end of the month and still drivers not up to par
going to have to change my avatar....
http://www.xtremesystems.org/forums/...2&postcount=11
monkey business :D
start installation, when installer unpack files and ask to continue, find and edit file (x64 example):
for Win 7
c:\ATI\Support\10-1_vista64_win7_64_dd_ccc_wdm_enu\Driver\Packages\D rivers\Display\W76A_INF\C7_94296.inf
for Vista
c:\ATI\Support\10-1_vista64_win7_64_dd_ccc_wdm_enu\Driver\Packages\D rivers\Display\W76A_INF\CH_94296.inf
find section
[ati2mtag_SoftwareDeviceSettings]
add new line below
HKR,, Catalyst_Version,,"enter any text that will be displayed CCC"
click next in installer
adobe flash player 10.1 beta has gpu acceleration (for ati 4xxx and 5xxx, and i think also for nvidia gpus)
flash player 10 had gpu acceleration for ages now, but I have not seen one single example of it being used anywhere...
if you want proper flash acceleration, get rid of XP/vista and move to windows 7.
I am with partical running 3 monitors gets to being a PITA .....
Release notes PROVE they are aware of the gray screen/vertical line crash and it is NOT fixed. Nice...
Glad I bought a eVGA GTX 285 that I will step-up to a Fermi. XFX wont fix my 5870 because they say its a driver issue. I cant do anything on my computer with the 5870 because of the Gray Screen Of Death (GSOD).
Anyone want to buy my 5870? (might have to stick it on ebay). /sigh
But it already does this? Ive had my rig since August and its always done that..Whenever I turnoff my external displayport monitor that is connected to my laptop it always reconfigures the desktop and turns off extended mode. When I turn the monitor back on, it reapplies extended mode automatically... ??Quote:
I'm looking more for fixes related to:
- Once a display on Display Port is turned off, the driver reconfigures the desktop, removing it from an extended configuration entirely (thanks)
Also it looks like Mobility Modding Cats 10.1 wont work..? Someone said tried to install them with out modding? Anyone have any luck?
Is this a screenshot posted before from the final 10.1 driver released today?
http://forums.guru3d.com/showpost.ph...4&postcount=92
Because i just checked the 10.1 beta that was leaked not too long ago and every version is newer...
http://img18.imageshack.us/img18/3933/101beta.th.jpg
Notice how here they typoed it as 9.10 :rofl:
Known Issues Under All Windows Operating Systems
Intermittent grey screen or vertical line corruption may randomly appear on the
screen
ahhhhhhhhhhhhhhhhhhhhhhhhhh
not fixed yet :shakes::shakes:
at least they said "WE KNOW THIS EXIST...", but the "may randomly appear" says to me "..BUT WE DON'T KNOW WHY THIS HAPPENS"
:p:
They didn't fix the problems with CODMW2 :down:
The 5800's have been out since october and they still cannot fix the extended display flickering issue. This is why i appreciate nvidia so much, better drivers, always has, always will. I have a 5800 and i cannot use my second screen because it flickers, it has been turned off for 3 months now. :shakes:
EDIT: I am patiently waiting for Fermi, then my 5800 goes to one of my customers.
Here are my results with AA and ANI, plus one bug report: This release doesn't properly put my CRT to sleep, it only blanks the screen. 9.12 and 9.12 hotfix did not do that.
Benchmark Log File created on 1/24/2010 at 3:32:51 PM
Number of cores 4 (max 8)
Specification Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Core Stepping C0/C1
Multiplier x FSB 21.00 x 196.0 MHz
Stock frequency 2666 MHz
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
Northbridge Intel X58 rev. 12
Memory Size 6144 MBytes
Memory Frequency 784.0 MHz (2:8)
CAS# latency (CL) 7.0
RAS# to CAS# delay (tRCD) 7
RAS# Precharge (tRP) 7
Cycle Time (tRAS) 24
DMI BIOS
date 09/03/2009
Motherboard Info
vendor ASUSTeK Computer INC.
model P6T DELUXE V2
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
DirectX Version 10.0
cardname: ATI Radeon HD 5800 Series
vendor: ATI
memsize: 1024
driverversion: atiumdag 8.14.10.0716 (Catalyst 9.12) / Win7 64
clockgpu: 980
clockmem: 1235
Audio:Sound Blaster X-fi Fatal1ty
Tests performed at 1600x1200x32, 4x FSAA & 16x Anistropic (Quality setting)
Results for Quake3:
AVERAGE FPS: 798.85
Results for UT2004FlyBy:
AVERAGE FPS: 574
Results for UT2004Botmatch:
AVERAGE FPS: 119.7
Results for Comanche4:
AVERAGE FPS: 159.8
Results for HalfLife2:
AVERAGE FPS: 429.5
Results for SeriousSam2:
AVERAGE FPS: 248.2
Results for Doom3:
AVERAGE FPS: 307.5
Results for HalfLife2_Lost_Coast:
AVERAGE FPS: 245.9
Results for Supreme_Commander:
AVERAGE FPS: 81.91
Results for Company_of_Heroes_DX9:
AVERAGE FPS: 312.4
Results for Company_of_Heroes_DX10:
AVERAGE FPS: 147.15
Results for Crysis_Island_DX9_HIGH:
AVERAGE FPS: 54.11
Results for Crysis_Island_DX10_VERY_HIGH:
AVERAGE FPS: 34
Results for Dirt2_DX9_High:
AVERAGE FPS: 99.27
Results for Dirt2_DX11_Ultra:
AVERAGE FPS: 60.21
Benchmarks finished at 4:32:00 PM
GRINGOMARKtm=193
Benchmark Log File created on 1/27/2010 at 2:25:51 PM
<Clip; same start-up info as before>
Results for Quake3:
AVERAGE FPS: 842.5
AVERAGE FPS: 569.2
AVERAGE FPS: 119.9
AVERAGE FPS: 158
AVERAGE FPS: 434.7
AVERAGE FPS: 250.1
Results for Doom3:
AVERAGE FPS: 306.6
AVERAGE FPS: 247.9
AVERAGE FPS: 82.22
AVERAGE FPS: 314.5
AVERAGE FPS: 148.55
AVERAGE FPS: 54.11
AVERAGE FPS: 34.16
AVERAGE FPS: 98.36
AVERAGE FPS: 60.17
Benchmarks finished at 3:26:07 PM
GRINGOMARKtm=194
I have the same display and the monitor itself is at fault. However interestingly enough, I don't get the issue with my 5870 nor with my older 8800gt. The GT2xx series however is another story....
Good to see they at least acknowledge the verticle grey line issue... now as for fixing it...
I uninstalled the drivers and installed 10.1 drivers from AMD.
http://img195.imageshack.us/img195/6...board01rnq.jpg
They show as 9.0
http://twitter.com/CatalystMaker
He made a post regarding that issue. They are 10.1.
Shucking fit man, I need that support for TV Wonder 650 USB Tuner on Win 7. Keeps BSODing on me that piece of tish.
There was a time when I hopped for better results (ones that can be seen with naked eye) but rarely got that from an ATi driver upgrade... Now, I just hope they work and don't screw something that worked before and can't even make that right (as in, sometimes they get to screw more then they fixed). :shakes:
You mean as good as the 191.07 killing hardware?
http://www.hardforum.com/showthread.php?t=1462586
http://forums.nvidia.com/index.php?showtopic=108974
