Well thats a LOW Room temp.
nice home made water block :up: , im trying to do the same but i just cant find some copper plates. where did you get yours :D
Online metals, industrial metals, mcmaster carr, whatever online small quantity raw materials stores you can get from googling "copper plate". Usually the shortest they'll sell is 1 foot long. I think Petra's carries 2 inch square ones, but they might not anymore.
Mick64 thats a nice block you have there...is it something youre working on? looks familiar :)
COoLBoX09 the piece copper I picked up was just from a local metal shop in Edmonton ...I paid $20 for a piece 1/4 x 4 x 6"....also if you want jig dimensions /pics let me know it might save you some time and headaches
Nice work mate.
Alway excellent to see people try to make there on things.
Well done.
Finally found some time to make changes to the original block design..
pin count has increased from 38 to 54 and the copper base is much thinner now...overall I am getting 4c lower load temps even with the nb block that was just added
should I leave the nb block without any channels ? Ive seen that the swiftech mcw-nbmax doesnt have any...so maybe it doesnt improve cooling much ...let me know what you guys think, btw the mb is a rampage 2 extreme
http://farm3.static.flickr.com/2804/...1d03fc41_o.jpg
http://farm5.static.flickr.com/4001/...91bbab7e_o.jpg
That looks pretty awesome for a home made, nice job man!
Shtrafenhoofen: room temperature in Alberta? ...Nice :) :up:
21.4 c
Speaking of home-made (kinda) waterblocks... has anyone experimented with wire EDM lately? There were a few guys back in the ProCooling days who did some neat stuff with it.
nice... block
did you remove the stepping?
how deep are the channels?
Hondacity the channels are 2mm deep, Im not sure what you mean by stepping
Mr. Morello thanks for the support :)...skinny doesnt seem to be interested :p:...
jk I didnt want to approach him because I really didnt think the block was in the same league as hk or xt, now Im thinking otherwise
If I was to change the inlet to a central position maybe there would be some more improvement
I might give it a try this weekend and make a new acrylic top with some jet plates
should I leave the nb block as is?
everest is not good for stress, Skinnee recommends :
OCCT v3.1.0 with the Small Data Set setting.... if you can OC a 4.200MHz ?
http://skinneelabs.com/143.html
JASSAF for the stress test i used linx 0.64, everest was used just for monitoring
I thought that linx stresses cpu more than occt but I might be wrong
little bit of occt for jassaf :)
http://farm5.static.flickr.com/4029/...15136cda_o.jpg
Amazing block bud. I do have what may be a dumb question that hasn't been asked. I am planning on making a P55 full coverage block, but where did you get the O rings for yours?
I picked up the o rings from a local store in Edmonton called Liquid seal
they stock any diameter you could possibly need
I will try to find their number so you can give them a call when you get going with your project
I'd appreciate it, thanks. I'm still in the finding a decent priced piece of copper for the base. I live in New york city but it seems no manufacturing goes on here :P
Good job !
Detale hope this helps you find the o ring s you need :)
www.sealsonline.com
Just a little update ...Ive decided to go with the xt look :D:D
temps look better already, but before I do any testing Ill wait until the IC7 cures
Will post some temps tomorrow..I hope the 2067 pins can chew up some serious heat
http://farm5.static.flickr.com/4045/...fd5aa401_o.jpg
