Originally Posted by
NaeKuh
first off the connector is a 4 pin and not a 3 pin found on normal DDC's.
I say 3, becuase its + - RPM.
The 4 pin would be + - RPM PWM.
The point in pwm is the pulse the pump, so instead of screaming at 4000rpm's, it would go in a wave from 4000 -> 1400 -> 4000 -> 1400, as the cpu header emits the PWM pulse.
How he had it connected was 2 was a molex, or looked like a molex with standard + - , and the other 2 looked like RPM and PWM headers that went directly to your cpu motherboard fan header.
Thats how you controlled the PWM.
It was really cool, and im sure gabe will talk more about it when he decides to.
