thanks!
Bouth VGA's are in paralel so those barbs will go to the second GPU :D
I mean this: (pic from MALIK)
http://img246.imageshack.us/img246/7213/malik.jpg
As you can see, the VGA's are in Paralel, and the flow don't know exacly if diminish or what... but malik have better temps and don't remember another project that works perfect... so I wanna try!
Trying can never hurt. If you don't like the temps you can always go series :).
The flow is halved for each GPU so they will get worse temps. But it's better for the rest of the loop (less restriction from GPU waterblocks), and GPU temps are not very important (as long as they stay reasonably cool).
Nice job so far, looking good ^^
jajaja yes let's try it! thanks for the coment!
Exacly what I wanna say before... but my english... :(:(:(:(:(
The only think that matters in the second loop is the GPU's so I wanna see if I have worse temps or the temps are right...
This night pics of the painted mid plate with the Black acrylic. Still working:(
Nice work mate.
Looking forward to the next update.
jajaja If MALIK can... we can:D:D
Thanks! Look down:D:D
Another update, first the mid plate just black painted:
http://img4.imageshack.us/img4/2580/mid1s.jpg
http://img220.imageshack.us/img220/9764/mid2g.jpg
Then with the black acrylic and others:
http://img687.imageshack.us/img687/5229/mid3.jpg
http://img237.imageshack.us/img237/3529/mid4.jpg
http://img517.imageshack.us/img517/1928/mid5.jpg
http://img19.imageshack.us/img19/5182/mid6.jpg
After that, mid plate in the case:
http://img521.imageshack.us/img521/9888/midcaja2.jpg
http://img98.imageshack.us/img98/233/midcaja1.jpg
http://img705.imageshack.us/img705/562/midcaja3.jpg
http://img203.imageshack.us/img203/8936/midcaja5.jpg
http://img85.imageshack.us/img85/1322/midcaja4.jpg
And finally this 2 pics of 2 probes that will measure the temp at the top and at the bottom of the case to control the ambient temperature inside the case. Bouth controlled by the aquaero and adjustin the fan speed of the 3x120 and 4x120 radiator.
http://img5.imageshack.us/img5/3294/sonda2.jpg
http://img25.imageshack.us/img25/2295/sonda1.jpg
Best regards! Keep posting and put your opinion pleasee!
sanxu can you fit directly phobya fittings to the gpu waterblock in the copper side or they also need some spacers like others compression fittings ?
http://img695.imageshack.us/img695/9340/gpubtps3.jpg
The fittings are 45 degree bitspower shown in this pic...
But i think that phobya compression fitings will touch the pcb for sure....
Some bad news of the project, mi PSU Silverstone zeus 850w is DEAD.
so... Silverstone Strider 1200 comming jajaja
I have been working with the cable routing and all the 5 1/4 bays, some pics today night or tomorrow!
Beste regards
it's coming along nicely.
the more I see this case the more I want it.
I like the fact that you can mount a 4.120 radiator at the bottom and stuff.
My HAF is showing it's space restraints not too bad though.
Subb'd btw.
v1ral
Nice work there! Makes me want to redo my setup.
Why cooler master r4s on the rad?
How did the graphics cards work out? Did you change it back?
@sanxu if the compressions are touching get a extender :), Nice build also mate subb'd~
SaNxU
What height does this rad mounts have?
saNxU,
Very nice build!
