Hi,
Thank you so much! Very good result indeed! Thank for share! :up:
So these kit have powerchips? :)
2150 6-9-6-28 18k everest Read :confused: you are bencing in signle channel check your 2100 6-9-6-28 that one is dual channel 20k and it's still without tweak with some tweak you can get 22k @ 2000 6-9-6-928 and 23k @ 2100 same settings
it's normal if cpu z detected 4gb but when you are booting check your memories they are 2gb and not 4gb
your problem is just RTL and it's very important in P55 and X58 platform try set them manualy;)
So what's the consensus on these, are they decent OC'rs for 2x 2GB PC3-12800 parts?
Also if you under-clock them below stock, can you get tighter timings, & can they run on even less voltage?
I mostly want to run at stock or under-clock w/tighter timings....
But on the rare occasion that I game, a decent OC (not hard-core) would be nice too!
Not sure I'd have quite as much luck as others with a GA-H57M-USB3 though :(
I believe the memory controller on the Clarkdale's (I'm getting Core i3-530) reverts back to the Core micro-architecture.
And of course a lot depends on the board and it's BIOS....
Any thoughts/advice on this or other g.skill RAM greatly appreciated!
okaaaay, thanks.
