Iam not sure I want to be near your delta fans :hehe: (All 8 of them)
bundy (or anyone else really)
Any ideas on when the SR-1 420 and 560 might be making their way to US stores? I know HW Labs was hit by the typhoon that damaged a lot of the Philippines, so that may be why, dunno. Just curious why these seem to only be appearing in the EU..
i'd give gary over at sidewinders a call. he was more than helpful last year when he ordered my 560GTX's. im pretty sure he already has them lined up but i'd give him a ring and see whats up.
anyone know a US distributor for NoiseBlocker fans?
Well i was surprised myself to find them in stores here (and ordered one fast, haha). There was absolutely no mention of them on HWLabs site, or actually no mention of them on reviews and marketing stuff. The SR-1 was heavily marketed but only in 120mm sizes. I wont complain, the 140mm variants are just in time for my new build :D
ben at mountainmods sized up my 560gtx and will be soon offering the hole pattern in the ascension cases so you can make use of the monster 560's in them.
perhaps that will get more people to buy the larger rads for some WC awesomeness :D
The only US 'distributor' listed on NB's website is FrozenCPU.
I e-mailed them asking if they had any plans to start carrying the BlackSilentPro series of fans but got no response. :shrug:
That's why I had a colleague of mine in the UK just order them for me from a shop in the EU and forward them over to me - didn't want to wait
thats the ones i want too. i'd like to see them under $10USD each though. i know thats alot to ask but i need 10 of them :eek:
I had 7 of them ordered for me, came in right at £100 which is about ~$163 by today's rate :( They're certainly not cheap
i put in a request to gary at SW to see what he can do to get them.
my delta's where actually a steal. i got them for $6 each on ebay but they sell for $38 a piece new.
the guy i got them from actually has a store. you can find him by searching for "the fan van"
NB's are extremely over priced for what they are and do. Rating wise, I'd put them close to SilenX though not quite as bad.
well do you have any other suggestions? i like a nice 90cfm+ fan but non of them exist in 140mm that have lower than 45db noise. im not a fan of yate loon at all.
currently i run my deltas at 9v and they are 24v fans. they are still a tad annoying thats why i want something different.
I won't argue that :) My main selling point with them was their rated RPM of 1700; I didn't even bother considering their noise rating which I'm sure is grossly understated. Unfortunately, as far as high RPM capable 140x25 fans go, they're about the only game in town at this point sans these non-RPM'ed Koolance 140s I just got recently (and I wanted something that had an RPM lead).
Plus they have a cool looking fan blade you can appreciate WL! :yepp: :ROTF:
It's good to see a radiator with multiple port options like the Monster Lite. I really wish more radiators would come like this.
bundy-
Do you have any °C/W measurement values for any or all of these rads you tested? I would like to make some calculations of expected delta T given different heat loads on each of these just to see how they compare. Thanks.
I would like to look at Black Ice SR-1 480 vs SR-1 560.
Hello Guys, here is my brandnew update for you - now there are 16 rads in this review. Sry, i had no time to translate it, so please use an online translator or just check the result charts. Thanks for reading :)
Update 25.03.10: Folgende Radiatoren befinden sich nun ebenfalls in diesem großen Testvergleich:
http://www.abload.de/img/phobya-logo1361w.jpg
Phobya Xtreme 280:
http://www.abload.de/img/img_3728nmjb.jpg
http://www.abload.de/thumb/img_3723ywx5.jpg http://www.abload.de/thumb/img_3727gm8u.jpg http://www.abload.de/thumb/img_37391k85.jpg http://www.abload.de/thumb/img_37484map.jpg http://www.abload.de/thumb/img_380498e1.jpg
Nachdem die Phobya Radis für 120mm Lüfter bereits seit einiger Zeit erhältlich sind, folgen nun die größeren Brüder f. 140mm Lüfter
Für diesen Test stand mir ein Vorserienmodell zur Verfügung, welches bis auf das fehlende Zubehör bereits dem Serienmodell entspricht.
Wie schon bei den Modellen für 120mm Lüfter, gibt es auch hier sowohl an der Front- als auch auf dem Wärmetauscher je 2x G 1/4"
Gewinde, um entsprechende Anschlüsse verwenden zu können. Die Gewinde an der Stirnseite bringen einen kleinen Durchflussvorteil
mit sich. Auf der Rückseite befindet sich eine Entlüftungsschraube, welche sich bei vertikalem Betrieb als nützlich erweisen kann.
Ingesamt weiß der Phobya 280 Radiator zu gefallen, die Verarbeitung ist gut und die Leistung ansprechend ! Dieses Radimodell
entspricht in etwa der Leistung eines Tripleradis f. 120mm Lüfter. Der Kaufpreis liegt bei angemessenen 60 Euro.
Technische Daten:
Material: Kupferlamellen, Vorkammern aus Messing
Farbe: komplett Matt Schwarz
Abmaße: (L x B x H): 338x145x60mm
Anschlüsse: G1/4"
Gewicht: ca. 1454g
Montierbarkeit: von beiden Seiten für Lüfter oder als Halterung
Gewindegröße Schrauben: M3
Lüftergröße: 2x 140mm
Druckgetestet: 2 Bar
Sonstiges: Entlüftungsschraube
Lieferumfang:
1x Radiator
8x M3x30mm Schrauben
2x Entkopplung
2x schwarze Verschlussschrauben
Als weiteren Phobya Radiator stand mir folgendes Modell zur Verfügung:
http://www.abload.de/img/img_4116fkd0.jpg
http://www.abload.de/thumb/img_41195mlr.jpg http://www.abload.de/thumb/img_4123qkln.jpg http://www.abload.de/thumb/img_4124379c.jpg http://www.abload.de/thumb/img_4945dmf7.jpg http://www.abload.de/thumb/img_4956fw0f.jpg
Der Radiator ist brandneu auf dem Markt und seit heute bei Aquatuning.de für knapp 60 EUR erhältlich !
Speziell für Gehäuse mit Einbaumöglichkeit für "Monsterlüfter" wurde dieser Wärmetauscher entwickelt,
natürlich lässt er sich auch extern betreiben und bietet aufgrund der 4x G 1/4" Anschlussgewinde viele
Optionen zur Verschlauchung. Durch die 2 mitgelieferten Blenden, lassen sich eine große Anzahl von
Lüftern der Größe 180mm - 220mm auf diesem Radi montieren ! Für den Test kam ein Coolermaster
200mm Lüfter zum Einsatz, welcher einen guten Luftdurchsatz und gleichzeitig leisen Betrieb gestattet.
Der eingesetzte Lüfter läuft mit max. 700 U/Min. Da es noch keinen weiteren Radiator dieser Größe gibt,
habe ich mich dazu entschlossen, dieses Modell hier aufzunehmen. So hat man eine Vorstellung, wo
sich dieser neue Radi leistungsmässig einordnet. Der Lamellenabstand ist groß genug, um auch mit
relativ wenig Luftdurchsatz eine gute Leistung zu bieten.
Technische Daten:
Abmaße: (L x B x H): 479x145x60mm
Anschlüsse: G1/4"
Gewicht: ca. 1976g
Lüftergröße: 1x 180-225mm
Lieferumfang:
1x Radiator
4x M3x30mm Schrauben
4x M3x5mm Schrauben
2x Lüfterblenden
http://www.abload.de/img/koolance_logo_400pxma68.png
http://www.abload.de/img/img_5053kwbls.jpg
http://www.abload.de/thumb/img_47906gkj.jpg http://www.abload.de/thumb/img_4800ggob.jpg http://www.abload.de/thumb/img_5048kydxr.jpg http://www.abload.de/thumb/img_5049kfexv.jpg http://www.abload.de/thumb/img_5050klhkx.jpg
http://www.abload.de/thumb/img_5110w688.jpg http://www.abload.de/thumb/img_5059oula.jpg
Von Koolance erreichten mich 3 Radiatoren für diesen Test. Wer sich die Bilder näher ansieht, wird erkennen, das die
Radis die Handschrift von Hardwarelabs tragen. Die Modelle sind für 1-3 Lüfter im 140mm Format ausgelegt.
Die Verarbeitung ist tadellos und die Leistung ab 800 U/Min. ist auch im grünen Bereich.
Ein durchdachtes Feature ist der Schutz unter den Schraubenlöchern. Wenn man irrtümlich zu lange Schrauben verwendet,
beugt eine kleine Metallplatte der Zerstörung des Radiators vor ! (auf dem 2. Bild in der 2. Reihe ersichtlich)
Bei Anschlüssen mit sehr langem Gewinde kann es vorkommen, das Gewindeverlängerungen notwendig sind, diese liegen
den Radiatoren im Lieferumfang bei.
Technische Details des 1x 140mm Modells:
Material: Kupferlamellen & Messingrohre
Anschlussgröße: 1/4"
Abmaße: (B x H x L): 13,3cm x 3cm x 17,1cm
Lüftergewindegröße: M4
Gewicht: 794g
Lieferumfang:
1x Radiator
4x M4x32mm Kreuz-Linsenkopfschrauben
Technische Details des 280er Modells:
Abmaße: (B x H x L): 15,3cm x 3cm x 31,6cm
Gewicht: 726g
Lieferumfang:
1x Radiator
8x M4x32mm Kreuz-Linsenkopfschrauben
Technische Details der 420er Version:
Abmaße: (B x H x L): 15,3cm x 3cm x 46cm
Gewicht: 1kg
Lieferumfang:
1x Radiator
12x M4x32mm Kreuz-Linsenkopfschrauben
Die 3 Koolance Radis sind in Deutschland zu Preisen zwischen 50 EUR und 75 EUR erhältlich
http://www.abload.de/img/aquacomputerlogoje3k.png
http://www.abload.de/img/img_3609agj2.jpg
http://www.abload.de/thumb/img_36143h1i.jpg http://www.abload.de/thumb/img_3626nh6w.jpg http://www.abload.de/thumb/img_36165dzf.jpg http://www.abload.de/thumb/img_3640dean.jpg http://www.abload.de/thumb/img_3653qd38.jpg
Die Firma Aquacomputer.de, bekannt durch viele innovative und erfolgreiche Produkte, schickt ihren neuesten Vertreter aus
der Radiatoren Abteilung ins Rennen: den Airplex Revolution 360/420 ! Die Bezeichnung lässt bereits die Besonderheit dieses
Wärmetauschers erahnen: es lassen sich sowohl 3x 120mm- als auch 140mm Lüfter verbauen, wobei jeweils eine Seite für die
entsprechende Lüftergröße ausgelegt ist. Für Auf- und Umsteiger der beliebten 360er Radis, die bereits den üblichen Ausschnitt
im Gehäuse besitzen, ist dieser Radiator also eine besonders gute Wahl, da man nicht direkt erneut das Gehäuse modifizieren muss.
Der Preis von knapp 80 EUR geht angesichts der gebotenen Leistung und Features in Ordnung. Es befinden sich beidseitig je 2x G 1/4"
Gewinde in der Vorkammer. Denkbar sind also u.a. Radi Sandwiches, oder einfach die Befüllung über eine dieser Öffnungen, als eine
Art Fillport. So kann man sich den sonst notwendigen Ausgleichsbehälter im Kreislauf sparen.
Eine passende Radiblende mit zusätzlichem Ausschnitt wird von Aquacomputer bereit gehalten.
Sauer aufstoßen lässt mich die Tatsache, das sich keinerlei Lüfterschrauben im Lieferumfang befinden und kein Inbusschlüssel,
um die 2 Edelstahlinlay auf der Seite f. 120mm Lüfter zu montieren.
Dies ist bei halb so teuren Radiatoren eine Selbstverständlichkeit, oftmals sogar in 2 Längen.
Die Lackierung meines Testmusters weist an einigen Stellen Unebenheiten auf, ferner sind die Lamellenreihen teils etwas verschoben. Natürlich ist dieser Aspekt eher zweitrangig, da man dies im verbauten Zustand kaum bis gar nicht sieht.
Der Radiator wurde in Deutschland entwickelt und laut Aquacomputer wird er auch hier produziert. Der Preis ist dahingehend gut !
Hardware Labs Black ICE Radiator SR1 140
http://www.abload.de/img/img_3830dpje.jpg
http://www.abload.de/thumb/img_3835cqfm.jpg http://www.abload.de/thumb/img_3841tq4p.jpg http://www.abload.de/thumb/img_38400srr.jpg http://www.abload.de/thumb/img_3855ar7n.jpg http://www.abload.de/thumb/img_3843ist4.jpg http://www.abload.de/thumb/img_38955rwq.jpg
Technische Details:
[LIST][*]Maße: 171 x 54 x 153 mm (BxHxT)[*]Material: Kupfer, Messing[*]Farbe: Schwarz[*]Gewicht: 680 g[*]Anschlüsse: 2x G1/4 Zoll[*]Lüfterkompatibilität: 1x 140 mm[*]Lüfterbefestigung: M4 Gewinde (beidseitig)[*]Preis: ca. 75 EUR
Testergebnisse:
http://www.abload.de/img/deltat500e589.jpg
http://www.abload.de/img/deltat800wujc.jpg
http://www.abload.de/img/deltat12003ul1.jpg
http://www.abload.de/img/deltat1400aun7.jpg
http://www.abload.de/img/deltat1700ju0r.jpg
Differenz (delta T) von der Raumtemperatur zur Wassertemperatur)
(ein niedriger Wert ist besser)
Durchflusswerte / Flowrate
http://www.abload.de/img/durchflusse5ta.jpg
Liter / Stunde
Hope this helps! :D
HW Labs Black Ice SR1 560 $179.95
http://www.dangerden.com/store/black-ice-sr1-560.html
That SR never ceases to amaze me o.O
Thanks for the review Bundy :).
I am hoping for SWC to carry the 140mm versions of SR1s.
I still cannot believe how much better the TC is than all the others at low RPM. How do they do it?
Does anyone know if TC will release a 140.4 rad? I would be really interested!
Looks like the Lian Li X2000 can do it ;)
Similar tall cases could hold them too i guess... maybe the PC-P80 ?
