nice score, what score would you get a 4ghz?
http://i49.tinypic.com/2z8dfsi.png
bench stable on air!
sapphire HD5770 V1 w/asus bios @1090/1350:
xp
http://i209.photobucket.com/albums/bb261/pvhk/19662.jpg
seven:
http://i209.photobucket.com/albums/bb261/pvhk/19379.jpg
^^ killer runs p!
My drivers has broken badly now. My 3dmark score doesnt change when I overclock lol. Time to format this corrupt machine .
My personal records for now:
http://i45.tinypic.com/24v78n9.jpg
Here is 20K with one card...
http://i48.tinypic.com/ev6khl.jpg
And crossfire action...
Strange enough when I go above 1000Mhz my fan sometimes reset itself after loading the first 3D06 test... Otherwise I could do a run on 1050/1400 :(.
Lucky that it didn't do that when I benched with one card :yepp:.
^ what is vantage like?
nice scores beta :) Have you tried a bit more core, like 1040-ish and less memory freq? I find after 1350mhz on these 5770's bandwidth seems to choke a bit. Just a thought.
Some of my best benches come at 1030-1040/1300-1350.
http://hwbot.org/result.do?resultId=920713
Here's my better 05 run on a single 5770, not optimized but with 1031/1400 the scores were consistently lower. This happened in Vantage, 01 and 03 as well.
Just giving fellow benchers a heads up. Unless you're pushing 1100+ on the core, 1400 and over memory isn't doing you any favors. If it was built on a 256b bus, the story would be a bit different ;)
With Asus 5870 Voltage Tweak (Thanks Asus) :D
Max AIR : i870@4GHz + 5870 1051/1351MHz with 1.31v
http://www.overclex.net/data/images/news/p20383.jpg
Max WATER : i870@4GHz + 5870 1112/1351MHz with 1.35v
http://www.overclex.net/data/images/news/p21016.jpg
Max LN2 : i870@4.2GHz + Asus 5870 Tweak Voltage 1198/1301MHz 1.35v under LN² -45°C
Impossible to have 1201MHz because bios limited ? or AfterBurner...
http://www.overclex.net/data/images/news/p22042.jpg
And now play with 5970 !
http://www.overclex.net/data/images/news/5970_1.jpg
2XHD5870 Club 3D+ HD5870 Powercolor with asus bios in watercooling: EK waterblocks
http://free0.hiboox.com/images/5009/...bfed548215.jpg
http://free0.hiboox.com/images/5009/...aff9347c04.jpg
My 5870 does 1GHZ with 1.225V :) Stable with every game i throw at it.
çà rigole pas ici! :)
sapphire HD5770 V1 w/asus bios @1100/1350:
http://img693.imageshack.us/img693/8771/19733.jpg
with i5 @ 4.2ghz and hd5850 @ 1050 w/ 1300 ram i get:
3dmark06: ~25000
3dmark vantage: ~16500
pvhk you are using wc right?
no, all on air: fan@100%
edit : and thermal paste "thermalright chill factor 2"
my asus & gigabyte cannot handle either...
vantage @1100/1350
http://img14.imageshack.us/img14/5672/p11811.jpg
I can do a 1050 run, but my fan always resets itself after the load off the first test... I don't know what the problem is, but I will find it out.
About the memory, I underclocked the core to 650Mhz and left the mem on 1200Mhz.
Then I did a 3D06 test, cheched the FPS and noted it. I did this untill 1400 and the FPS still rose. When I did a 1410 run it kept the same, and for fun I did a 1420 run, FPS got lower, and 1440 was a crash after the first test.
So I don't know, but till 1400 my FPS keep rising and stable then.
