Going to retire the Detroit AC tops hey.
Show us some photos when you do.
Hell no. Those tops rock. No I have an idea for a new build using one of those double wide DD cases. Thinking 2 loops with two of these units. So 4 pumps altogether. Each loop will have 2 D5's. Kind of a waste but I am thinking aesthetics as well as loop redundancy which makes me sleep better.
Dual DDC already exists...I am using one in my loop with two DDC 3.2s.
http://www.sidewindercomputers.com/ekdututopg1a.html
I hope at least one sample is already on the way to skinnee or Vapor lab desk :yepp:
do i really need to answer that?
:rofl:
i have enough pictures of DDC's to make you also hate D5's.
:rofl:
So how is this solution better then dual DDC's on a dual ddc top?
Im very lost.. you guys are COMPLETELY FORGETTING why we get D5's over DDC's now are you?
How about.. umm.. cuz they were hush quiet when downvolted.. now u have two of them so you lose the noise edge they had over DDC's.
And if you think your smart, and u downvolt both of them, well, you just matched the noise of a DDC.
This makes no sense unless u already have dual D5's and u need a top for them.
Otherwise if ur getting an entirely new pump package, and you pick this over dual DDC's.. oh boy... time to bust out miyuki. :X
Guys think about it.. its a 160 dollars for top + 1 pump.
Umm dual ddc's + xspc tops = 160 dollars..
Whats the winner? dual DDC's with tops OR a single D5 /w dual top?
i'll say this once more, and i dont intend to offend d5 users.
You guys just havent been in the hobby long enough.
You WILL EVENTUALLY get a DDC. And once u do, you will HATE a D5.
(like in the old days, we told everyone, eventually you will get a 120x3 class radiator, and now its the standard.)
:rofl:
This is speaking from experience.. i had 4 D5's and probably now over 10 DDC's total. (lost count of ddc's)
Or you get a Typhoon III. :p:
I'm with NaeKuh on this one. DDC's are the way to go. I'm among the early DDC adopters and i never looked back...
D5's would be great pumps if DDC's hadn't appeared...
XSPC actually did have something similar. They new revision of it is a dual loop setup. It seems they stopped making the original version. I went looking a while ago and couldn't find it.
http://ep.yimg.com/ca/I/sidewinderco..._2081_29401369
except that looks lame and this looks awesome.
except it would be the dual version
http://specialtech.co.uk/spshop/file...X-RES-100a.gif
This is just one step away from an acetal version of the T3.
Make it dual 5.25, short, with 4 ports and of course with EK quality - it will be a killer.
Except T3 costs $30 less, another $65 less for no pump #2.....
That's $130 for a serial/parallel setup or $225 for an arguably more powerful serial loop setup...
I think that's a fair price, by reading the above posts I thought it was gonna be alot more than that? 95$ is about what to decent tops would cost anyway. Hope they have some still in stock, waiting for this.
This has nothing to do with performance (well to a degree) as much as the aesthetics with me (cannot speak for others). Seriously I like the industrial look of the D5 and having 2 of them in a loop is more for redundancy more then anything plus it does add to the looks as well. Everyone who has seen my build (especially in person) loves the aesthetics of it. I could have easily went with the DDC's as well but I did not want to. In my most recent build I took out the HDD cage to make room for only the 2 pumps, drains etc to make it look cool and it worked. It was what I envisioned. Now I have another vision with 4 D5's with 2 of these cool EK tops and everything in a double wide DD case because I have a cool idea to make it all look awesome! It will have performance. As much as the DDC's? Of course not but that is not what I want either. The DDC does not look industrial at all to me. It looks like a block. Sure I can throw a couple LED's to make it glitter and stuff but I was and still am after a specific look the D5's offer. As for noise.....with my fans that I have I cannot hear my pumps even if I had them loose and bouncing off of the bottom of the case. :rofl: I have both pumps running on 5 at all times.
i have 5 ddc's in nadeshiko. :X
