Can you over clock 2 HD5770s at the same time with GPU Clock?
Socket Man crank that up and post some Benchmarks! :cool:
I did this so far...The vantage is @960/1400
I have to say that i find the ASUS bios rather unstable...I cant finish 06 or vantage anymore @1040 while before i could...Rather strange...
http://img3.imageshack.us/img3/3537/27121.jpg
http://img62.imageshack.us/img62/3002/58047.jpg
http://img3.imageshack.us/img3/3645/vant9566.jpg
Great to see some nice benchmarks with the 5770. :up:
Are you running Asus Smart Dr or MSI AFterburner 1.3.0 for Voltage control?
Try adjusting voltage. That might stable it out and allow for higher clocks.
How do you like UT X48?
i have noticed X48 does better at 3dMark05 and 3dMark01 than my DFI JR T2RS P45.
I'd like to try your MB out. Should i get one? or Stay where i am at?
Actually its LP DK X48!!They cost like 100 euros now so yeah try it out if u want but only for xire!single card it wont be that different!
Well i have maxed out the volts on MSI aft. but i dont think its needed that much,will lower tommorrow by trial and error!
1 more thing i noticed!While MSI reports 1,35 volts,my DMM shows 1,39!!!WOW 0,04 is quite big isnt it?
not a fight! :wave:
Just to say that the asus bios works fine with my gigabyte HD5770 freshly flashed!
http://img20.imageshack.us/img20/5081/p11021.jpg
I want A QUAAAADDDDDD too....My scores get so low cos of my C2D.........:(:(
Why GPUZ does not correctly detect my OCed specs??I use the 3,6 version too!
you can download the special rev of gpu-z for hd5700 over at techpowerup forum!:wave:
you did not made a good research:
http://forums.techpowerup.com/showthread.php?t=106483
it was not easy to set up my CF!
MSI afterburner was a no go...
But finally with ccc & voltagetweak everything works fine!:wth:
asus bios on the 2 cards (sapphire & gigabyte)
http://img8.hostingpics.net/pics/920484p15161.jpg
Nice score!But aint it a bit low..My single and c2d does 10k.I mean it should be somewhere like 16,5k...Maybe put memory 1400 and clock that quad a little more like 4ghzish!!!and core @1030-1040...?
As I said running single card is easier
here's my single sapphire hd5770 on another rig
http://img9.imageshack.us/img9/6165/19632.jpg
http://img8.hostingpics.net/pics/989533p11651.jpg
And don't ask to much to my q9400 : it's the max it can do...
Thanks for all of your great work pvhk. :up:
I'm stumped at the performance on the Futuremark benchmarks. :shrug:
With single HD5850 I can score P18,000+ on Vantage, 24,000+ on 3dMark06 and 89,000+ on 3dMark03.
With my xfire HD4770s I can score 24,000+ on 3dMark06 and P16,000+ on Vantage.
What is going on? :(
nothing wrong, just a q9400@3.642ghz here...
USB boot disk (required my hard drives to be unpluged), containing Atiflash and the Asus bios named 'Bios.bin'.
In startup:
C:\>atiflash -f -p 0 bios.bin
This command will force whatever you have titled 'bios.bin' to be written to the graphics card bios, so make sure you have the right one, and if it anything goes wrong, your card dies.
Vantage score at 1000 / 1250 was P17882, a little lower then my sig score because that was done at 960 / 1445. I will try a run at 1000 / 1445 some time, but cant be bothered just yet.
CF HD4770@1000/1100 w/asus bios:
http://img194.imageshack.us/img194/3493/p15212.th.jpg
CF HD5770@1030/1300 w/asus bios:
http://img8.hostingpics.net/pics/621408p15409.jpg
gpu score matters...
dats great big donkey crack!!! :shocked:
