It means New DumbAss :D
NEAR DEATH ALWAY'S :rofl::ROTF::D
I once knew a band called NWA, maybe there is a connection :D
great, NDA violation once again..
What NDA? It's already available in stores :D
http://www.provantage.com/amd-hdz965...x~9AAMD2AT.htm
http://www.shopblt.com/cgi-bin/shop/...!#Availability
keep the results coming man! this is good news!
Great test :up:
very sweet! :toast:
so 10-15W less load power and 100+mhz higher cpu, nb and mem clocks, not bad for a rev change... but not as much as i expected tbh... 100-200mhz is only 3-6% for a 3400mhz cpu... the nehalem c0 to d0 change brought bigger boosts.
but as tesco says, every little helps ^^
:clap::clap::clap:
Small world it is, the phones started ringing soon enough. What can we do, we are not mean guys :D
Stepping= minor fixes(errata mostly) while revision=more serious silicon changes(think adding virtualization and DDR2 support in the IMC with RevF,changing cores with Barcelona which got a "new" B letter in revision nomenclature,changing process node with Revision G and C,adding more cores with Revision D). Enough examples :)? Logically stepping change takes a lot less time than a revision change.
As for NDA on new C3 products,they probably wanted to wait for board manufacturers to produce new BIOS versions which would in turn support more advanced power management which comes with new C3 chips :).This new features will shave off a few more watts in idle mode,on top of what Monstru presented in his results. Load numbers won't change on the same system though(they are quite a bit better than with C2).
No NDA for this release as far as i know. I'll start testing tomorrow :up:
