I didn't make the avatar in my sig ;)
It was a friend, who is graphic designer :)
Normally the avatar is also animated but I don't have an Xtreme account....
Thank you Barus :wave:
http://www.abload.de/img/dsc02637h51r.jpg
One mips screw is missing because the hexagon hole got damaged -.-'
I only knew this from the Heatkiller screws
The heatkiller screws were really crap
Really like it with Acrylic :)
http://www.abload.de/img/evgaxr23.jpg
http://www.abload.de/img/heatpipepgj0.jpg
http://www.abload.de/img/pcbrhyo.jpg
http://www.abload.de/img/corsairuri9.jpg
http://www.abload.de/img/ramkfmz.jpg
http://www.abload.de/img/ek15dsi.jpg
http://www.abload.de/img/ek2teeb.jpg
http://www.abload.de/img/img_10307ghs.jpg
some painting preparations :)
http://www.abload.de/img/img_1288necr.jpg
i will fix a transparent green foil behind the xfi emblem so it will not glow anymore white
http://www.abload.de/img/img_12964df2.jpg
case is back from powder coating
http://www.abload.de/img/img_1491ixze.jpg
http://www.abload.de/img/img_147329ec.jpg
http://www.abload.de/img/img_1469b9sz.jpg
http://www.abload.de/img/img_14708yam.jpg
http://www.abload.de/img/img_148079wq.jpg
http://www.abload.de/img/img_1483zbp6.jpg
first fitting :up:
http://www.abload.de/img/neuesbildb4nm.jpg
and here are some new feets for my case
http://www.abload.de/img/img_216936hy.jpg
http://www.abload.de/img/img_2173d5rm.jpg
http://www.abload.de/img/img_2180v6sx.jpg
ek reservoir will be mounted there
http://www.abload.de/img/img_217876kv.jpg
how did you remove the red paint on the mainboard cooler? Did you paint over it or what did you do?
just aceton ;)
but there are still some "shadows" of the painting
you can't remove it 100%
but this doesn't matter because in future the mainboard will be watercooled
thats the same in my project. I didn't imaginethat aceton is the magic fluid :D
Those are some really nice pics there 1337_alpha! Keep working on it!
Wow, that build is turning out to be gorgeous.
What feet did you use? I really like them, I'd like to pick up a pair for my mothers build, in an old coolermaster atc 220 :) how high are they half an inch?
I bought them from fhantastic and fhantastic bought them from PPC
They are ca 0.60 inch high
Beautiful work, definitely turning out great.
There are some great news
From now on my project will be sponsored by Aquatuning and Phobya
Thank you very much :)
http://www.abload.de/img/aquatuninglogomaxdvof.png http://www.abload.de/img/phobyalogopkq8.jpg
Next week there should be an update
Nothing to do, so I changed the screws
http://www.abload.de/img/img_25921jqn8.jpg
lol, nice detail work.
You're like me, have to find something to improve on.
loooookin' goooood :up:
a paket from caseking :)
http://www.abload.de/img/img_259520l2.jpg
http://www.abload.de/img/img_2596n12q.jpg
bitspower connector for silentstar and the ac flowmeter
http://www.abload.de/img/img_260654qf.jpg
and here some pictures of the acrylic glass and the pump
mounting (prototype)
http://www.abload.de/img/img_2610223h.jpg
http://www.abload.de/img/img_2619z3h2.jpg
http://www.abload.de/img/img_262291le.jpg
http://www.abload.de/img/img_2627v4ok.jpg
yeah looking good :)
Stunning!
Mmmm, that does look great! I like the snow pics ; )
thank you guys
tommorow there will be a next paket from aquatuning with lots of things and the pc will running the first time
small update
http://www.abload.de/img/img_26368f85.jpg
http://www.abload.de/img/img_2640rcrx.jpg
but it's not 100% perfekt
the next few days i will buy some small files and correct the hole for the 3 pin connector
and i'm thinking about if i shall sandblast the acrylic glass to get a matt surface
Swt I got same case and mobo. I also want to powdercoat the case but currently a bit strapped for cash. Question how did you prep the case for powdercoating? so the screws and all would go back in. Did you take out any rivets or just leave it as is?
the case got powdercoated in one piece
i just removed all plastic parts
Yesterday I began to install my new system
at first the cables
http://www.abload.de/img/img_2673zupb.jpg
now removing the parts i need from the old sys
http://www.abload.de/img/img_2674vu9j.jpg
it was a good decision not to sell the xspc reservoir :D
http://www.abload.de/img/img_2681i6yi.jpg
my "old" enermax
http://www.abload.de/img/img_2686f6i1.jpg
hmmm something isn't correct...
Epic Facepalm?!
http://www.abload.de/img/img_26891689.jpg
let's try again :D
http://www.abload.de/img/img_26937650.jpg
let's take a look at the hk 3.0 :sick:
http://www.abload.de/img/img_2695h6ux.jpg
http://www.abload.de/img/img_2696w60c.jpg
http://www.abload.de/img/img_269705s2.jpg
