impressive
Thanks.. seems both my DFI UT X58-T3EH8 and Asus P6T6 WS Revolution with xeon cpus can really push uncore to 4400-4600+ frequencies on just air/water cooled cpu :D
Very Cool Vali eva2000
2300Mhz :shocked: :up: Uncore 4600Mhz :up::yepp:
Top Board and CPU, i can max 4376Uncore
i think my Board is the problem
Trident is a good memory.
The lower voltage and higher memory timings cl7, cl8 2000Mhz
http://www.playwares.com/xe/files/at.../screen001.jpg
8-9-8-24-88-1T 1.66v
http://www.playwares.com/xe/files/at.../screen000.jpg
7-9-7-24-105-1T 1.66v
Nice namegt - paired with excellent cpus too :)
Playing with my Xeon W3570 cpu and these Tridents and they're going pretty well for just water cooled cpu in 28-32C ambients http://i4memory.com/f54/w3570-3847a6...olution-20800/ :)
Best 32M Pi time @4821Mhz 7m 27.016s beat my 4830Mhz time at 7m 27.157s
http://fileshosts.com/intel/Asus/P6T...7m27s016ms.png
Max Validation @2050Mhz 6-9-6-22 1T at 1.78v
http://valid.canardpc.com/cache/banner/842084.png
http://fileshosts.com/intel/Asus/P6T...cpuz_valid.png
Impressive results. What mem voltage have you used to get 6.9.6.22 @ 2000 ?? vvt voltage? Thank you. Really nice.
thanks voltages in screenshot turbov
ddram bus voltage = vdimm = 1.78v
qpi/dram = cpu vtt = 1.5375v
Great review and in depth testing + results eva :up:
I grabbed a set of these when they first came out and have been really impressed for the money.
They have worked flawlessly in both my DFI T3eH8 and RIIE and have been up to 2140 mhz 9-9-9-24 @ 1.66v :)
I haven't pushed them really hard as I did not want to start posting in the graveyard but these use the BBSE chips and seem far more robust than those dodgy batches of hypers...
*hugs his kit* :D
I have a kit of these, they are really great ram for the money.
They do DDR3-1600 6-7-6-18 tRFC=60 at 1.535v completely stable on my R2E.
Thanks Biker yes indeed excellent memory for 24/7. It's priced very well in Australia too relatively to other kits. Looking forward to more kits for P55 dual channel testing soon (hopefully before xmas break) :)
I love the way you lay out quick compareable results George :up:
I go to look for the next set to get just looking over your mem post makes it eazy lol:D
Hello !
I have problems to config GSKILL Trident 3x2 2000Mhz at 1600 with timmings 7 7 7 20
I'm sure it is possible.
My mobo is Gigabyte X58 UD7
I test with 1,4v and 1,5v in qpi/vtt and 1,66v in vDimm but nothing helps.
Can anyone help me ?
sounds like you may have a bad kit. I was having the same problem. I RMAed the ram and now 6-7-6-20-1T at 1600mhz with 1.25v VTT and 1.6V VDIMM
I can also run 1900mhz with 8-9-8-24-1T at 1.425v VTT and 1.64V VDIMM
TRY another kit!
http://hcidesign.com/memtest/download.html
HyperPI / y-cruncher also.
Very impressive results! I have 6gb of cl9 2000mhz and it has been awesome thus far.
Finally I buy a new kit and work without problems at 1600Mhz 6 7 6 18 1T
The problem is If i can justify that my old kit is faulty if I can run them at 1600 8 8 8 22 with 1,6vdimm or 2000 at 9 9 9 24 at 1,66vdimm ?????????
The lower cl works better on RE2 than Evga Classified and cl6 it's almost impossible :( it's my opinion only
I think it's time to change the memory, maybe some Elpida Hyper :)
