:hump:
@Monstru : well...we waiting your result mate...
ehhh ,:welcome: Dude you really are in the wrong forum :stick: this is eXtreme Systems where we game only 3Dmarks :doh: , theres pleanty of Games only websites dude pick one in :google: :up: , good day.
@ Zolkorn - Crazy GPUs indeed just crazy :yepp:. Great job clocking those cards bro , now get them cold :up: i wont be surprize of 1200+ Core :D , thanks for sharing bro and keep up the good work :YIPPIE:
Regards: Angelo.
Yes sir, will do. :)
I allready did HD5870 vs GTX 295 stock and OC on P55. Right now I am testing 2 x 5870 vs 2 x GTX 295 stock and OC on P55. After that I am testing 1 vs 1, 2 vs 2, 3 ATI (and hopefully, pretty soon 4 ATI's) on P6T7 - X58. These are done for a second article about 5870, multi GPU scaling and performance on P55 and X58. After I finish with these....only then I will have time to really bench, not just test 3dmarks and games at puny clocks, on air :)
Thank you very much Vince. :D
Or like this? ;)
http://www.elmor.se/img/news/extreme21774.jpg
elmor - how did you find the scaling from 2 GFX to 3 GFX in 2k5? I am getting something like ~100 points, with i975 at 4GHz. 2k3, 2k6 and Vantage still scale though.
Ok, I edited, I just finished running 2k6. So it is like this:
2k3 - 13000 points from 2 cards to 3 cards
2k5 - 400 points from 2 cards to 3 cards
2k6 - 1200 points from 2 cards to 3 cards
Now I am running Vantage. Let's see how this goes.
yeah i found the same, very little scaling above 2 cards,
They are soo hungry for my pci-e bandwidth and cpu mhz its silly
Elmor - I realy do not get these numbers, compared to what you've got. Yes, this is test& review set-up (drivers on quality, etc), but still the difference is huge. I am installing Windows 7 32 bits as we speak to also check on that...
ZoLKoRn - sorry for messing with your thread bro.
http://lab501.ro/wp-content/uploads/...antage-3cf.jpg
http://lab501.ro/wp-content/uploads/...e-3cf-High.jpg
http://lab501.ro/wp-content/uploads/...3cf-Xtreme.jpg
monstru my friend, you "missed" the GT1 in ALL those benches.....Something is wrong in there I think... :(
What happens when you go beyond 1370 MHz mem ? Does it lower your scores then ? I heard it would still be stable but because of the error checker resending the data the performance would drop dramatically.
But nice scores so far !! Cant wait until i can play with mine !
AH....only now I see GT2 is WAY higher then GT1. But I cannot seem to find the problem. Almost the same happens on WIN 7 32bit, just the H score is higher.
So it is like this:
P55 - 1 card - normal GT1>GT2
P55 - 2cards - normal GT1>GT2
X58 2cards - normal GT1>GT2
X58 3 cards - abnormal - GT1<GT2
SO...wtf?!?!?
