Thanks for the reply eva2000. That was def. a while ago and from Aussie Kingston.
Well after testing with B2B 12 tonight I quickly got 2000Mhz 7-8-7-20-1T Memtest stable 100% with much lower voltage.
P6T Deluxe V2
920 D0 #3911A330
Kingston Hyper KHX2000C8D3T1K3/6GX (Kingston USA RMA Received 10/5/09)
20x200
DDR3-2000Mhz 7-8-7-20-1T / B2B-12
vdimm 1.70v
vQPI 1.52v
http://i580.photobucket.com/albums/s...Mhz_7-8-7-.jpg
I got home, set B2B to 12, reduced vdimm to 1.70v, reduced vQPI to 1.52v and set timings to 7-8-7-20-1T and Memtest ran 100% 8 instances maxmem. I will now run LinX 10 passes and if that passes then will start lowering voltages till I get errors. Then run Prime95 x64 overnight.:up:
These are the first and only settings I have tried or tested tonight. Once I am done finding stability with lowest volts at these settings I will test max frequency CL7 & CL8.
http://i580.photobucket.com/albums/s...-8-7-20-1T.jpg
