Ya may want to check out the case I built here http://www.xtremesystems.org/forums/...d.php?t=183001 ya may get some ideas from it I finshed the case but have not been able to afford the rest of cooling gear but will get there one day:D:up:
Bluc i already have your case bookmarked and everything lol before i started designing my case i searched all the forums for any custom case builds to see what would work. I really like how you did yours in wood i think im gonna work on a wood model so i know exactly how much material i will need before i buy the aluminum. Also i can get wood for free from my school's wood shop so that is another reason why i would do that. If only i had time to take out of my schedule for robotics for this...
Hey, a bit random but did you make all of these desigs only in sketch up?
Just an update on this.... the original design is currently scrapped. I have decided to make a smaller actual case and go with a separate watercooling section... kinda like a pedestal. What will hopefully be different is that it will all be modular because the ideal situation would be an individual loop for each gpu. Yes i know. That sounds crazy but i would like to work towards that kind of goal.
i shall post new designs in a bit... once i get some finishing touches set up
