BTW, here's my specs:
Biostar TA790GXB A2+
BFG 9600 GT OC
2x1 GB Kingston Hyper X dd2 800
250 HD
500W Tacens Supero
You can try following:
-raise your cpu vid up to 1.40v (1.35v -> 1.40v )
-raise your cpu-nb vid up to 1.30v (1.17v -> 1.30v )
-lower your nb multi from 10 to 9 or 8 (2000 -> 1800 -> 1600 ) and after that also ht multi to follow nb frequency
-lower your ram divider (800 -> 667 )
-try other ACC values, if you use AUTO try other from -12 to +12 on all cores or per core
-see if newer bios is avaible for your mbo
-and last, try lower cpu multi for second core in AOD (13.5 -> 13.0 -> 12.5 etc ) if it helps you can create startup profile
i already did those things and i still get the same results. did i get a defective core?
It might be worth stripping your system to the bare minimum components & seeing if that makes a difference. If i saw those symptoms under normal circumstances I'd suspect the PSU not being able to deliver. Anyway, I wouldn't give up & wouldn't say the CPU was at fault until I'd eliminated all other possibilities. Best of luck & hope it works out for you.
i just recently bought a new PSU for my system and it dint to me any good. i still get the same results. also used the onboard video i still get the same results.:( i really dnt know...
Your second core is not fully stable or biostar bios is not the best one for unlocking, with your description of problems it looks like running windows XP is the most stable without sound driver (3D works?), probably cpu can't handle irq assignment with two cores enabled, do you have onboard sound or external pci / pci-e sound card? If you use onboard sound you can disable it in bios and borrow pci sound card from a friend or someone and than test your configuration again, if it works fine under XP than you can buy sound card and stick with most stable XP or if two cores is a must have (no htpc and gpu accelerated playback) you can sell your Sempron and buy regular X2 Athon II and problem solved
but what makes me really confused is that its Prime 95 stable for 6 hours...:(
Hi Everyone
Got myself a sempron 140 BATCH: 0937FFI from Microcenter. Sucessfully unlocked it using an Asus Crosshair 3 mobo, BIOS Ver 1003. Thing to note, it failed to unlock with the default bios it shipped with - Ver 0703. Thought this info would be useful to someone as the previous one i got - BATCH 0932BPMW(??i already forgot..grr) failed.
Now, to overclock :D
Thanks for sharing useful information to others! :up:
Wow, 5500 thread views and still counting :) Viva la Sempron! :D
i also got this and asrock 780gmle/128 second core is stable but the problem im encountering is when i shut it off and turn back on sometimes its detected as sempron 140 , then i turn it off again and back on and its x2 again any settings you recommend?
i already tried per core / all core from +12 0 -12 settings still no luck on the sed problem
It is bios / ACC related problem and there is nothing you can do except for waiting the new bios version to arrive, if you have first release update it to P1.10, it is not so big problem as hitting reset button after power on which still shows up on some Asrock mobo's
Here's my chip:
Processor: Sempron 140
Stepping: BL-C2
Batch: 0948FPMW
Cooling - CPU: mini watercooler Tt Bigwater 760i (pump @ 7V)
Motherboard: ASUS M4A78T-E
Stability tests:
http://img248.imageshack.us/img248/9...371275vp95.png
I'm really satisfied, ~ 840MHz OC at ~ 0.1V undervolt :) Memories are 4x1GB cheapo Corsair XMS DDR3-1333 C9 hence crappy speed/timings.
Got one for a little fun with it.
Unlocked to X2:up:
Batch: 0944BPMW
Cooling: Scythe Infinity + 120mm fan.
http://www4.slikomat.com/09/1219/mzy-Orthos.jpg
Quick SPI1M and SPI32M.
http://www4.slikomat.com/09/1219/uqz-SPI1M-.jpg
http://www4.slikomat.com/09/1219/8fd-SPI32M.jpg
great oc and benching guys, :up: greetings from neighbourhood :)
I picked up a 0939 (had to! miss the 939 days), and it unlocked perfectly. The chip isn't stable at all in the GD70 though...even at stock settings.
I managed to get it up to 3.9 on the stock heatsink. It was for a low end build I gave to my dad. He has it now...so no more testing/screenshots :\
Cele303 I saw you had this thread started so I thought I would post some of my 140 results here unless you would rather I didn’t?
http://i262.photobucket.com/albums/i...wprimecpuz.jpg
Bring it on man! :up: I'm proud to have unified thread, almost 7000 views! :up:
Your scores are awesome btw! :)
Thanks Cele303. I’ve read some of your posts and noticed you have some awesome results yourself.:clap:
I could unlock sempron 140 processor and its prime,occt,linx stable on stock.Actually I could easily overclock it to 3.7GHZ @1.475V.
I could actually get to 3.8 but requires > 1.5V :(. And my cpu temps are rather good at 45 degrees
cpu-z validation : CPU-Z Validator 3.1
One issue is, if I enable cnq my system just freezes when it tries to lower clock speed. Same behaviour at stock and overclocked. What do you guys think, problem with bios(790XT-UD4P) or processor?
cnq works ok without unlock.
batch :0944CFM
mine won't getting to windows unlocked :/, I haven't tried turning off cool & quite, yet though this was test on vista 64 bit. it's really gona have windows 7 on it. but for now the baord seems to be a bit weird it won't turn off lol it bsod's on turn off. ram is stzable windows is stable just happens when you go to shutdown :(
So we meet again cele :cool: Great job as usual.
Just got done with an entire 2d round up with the sempron 140 :D negative acc so gets me a red validation but w/e
http://valid.canardpc.com/show_oc.php?id=965336
http://hwbot.org/community/submissio..._140_24.84_sec
http://hwbot.org/community/submissio...40_16sec_614ms
http://hwbot.org/community/submissio...in_34sec_929ms
http://hwbot.org/community/submissio...min_7sec_500ms
http://hwbot.org/community/submissio...40_31sec_435ms
It unlocks but Ive no need for it tbh, just gonna put this in a media center pc as an x2. £15 what a bargain.
Hey El Gappo! It's always pleasure to see you and I love to check your oc man! Oc with phase is brutal fun, I wish I have one :)
Can I ask you what's wrong in your 32M run with nb 2000? That was a quicky or not stable at 2000+ mhz?
What kind of weird stepping is this on Sempron 140 :) NAEIC AE 0942CFM
Does anybody know something about that stepping?
I ordered a Sempron 140, it will come on Monday.
The first ones were all CAEEC, now they are NAEIC, I don't know what is the difference between them, but if you can unlock it and oc it, who cares about the difference :) Give us some feedback when you receive it :up:
