All the milling for the capacitors is done. Now comes the water channel milling.
http://www.evga.com/forums/upfiles/4...9AFB9DC34E.jpg
this should help pretty up the edges
http://www.evga.com/forums/upfiles/4...4AFF80FC5E.jpg
That is one high performance sander!
it certainly is!
Look at the accuracy of it:
http://i590.photobucket.com/albums/s...0914092210.jpg
Was shooting for 3.75". I got it to within 1/1000th of an inch
http://i590.photobucket.com/albums/s...0914092259.jpg
I'm in dire need of this block. Since I made the switch to H2O my Vreg temps shot up 15 degrees at idle.
The block is going well. I am trying out new milling bits, and tapping methods. I would like to get a working prototype build by the end of this weekend. There isn't enough hours in the day to get all the things that i need to do! :rolleyes:
are you making these using only non-CNC?? I can't imagine you being able to charge for more than materials + 25 cents/hr for your labor... how are you going to do these en mass?
yup, no CNC machine here. no plans for en-mass, and only made to order. Once I get the feel for them, making them goes much faster.
A thousandth of an inch is pretty damn accurate!
Thank you. I got some aluminum to practice with as well.
Here is the Alum version I just banged out. Will work on it more tomorrow.
http://www.evga.com/forums/upfiles/4...57CA3394E2.jpg
and the side by side
http://www.evga.com/forums/upfiles/4...6EF43CB1EB.jpg
now which looks sexier... the Aluminum and black, or the copper and black
http://www.evga.com/forums/upfiles/4...EDC6143D3B.jpg
OH NO! Aluminum.
*Water community shudders in fear*
Copper all the way.
This thread makes me wish I had this board JUST so I could get this amazing block-to-be...
Incredible work sir.
Why so?
http://www.evga.com/forums/upfiles/4...A01F9AC337.jpg
Here is more progress.
aluminum + copper + current = corrosion.
http://www.evga.com/forums/upfiles/4...499E088FD6.jpg
Drumroll......
and I don't mean mixing metals on the block, it will be either entirely Alu, or Copper. I am referring to mixing a Copper CPU block, with an Aluminum chipset block?
Im wondering why after all the bickering and heartake on the subject of Aluminum/Copper corrosion on this forum we don't have a dedicated sticky thread yet? :shrug:
here we go again...
