Everest memory performance is reduced
C-STATE disabled is a bug.
Now msi p55-gd65 been resolved through BIOS updates.
True Black 120 1156 kit
Socket 775 Thermal light guide was used
Bottom guide should be produced.
Various P55 boards were tested.
Gigabyte P55-UD6 / EVGA P55 FTW / MSI P55-GD80
http://www.playwares.com/xe/files/at.../screen000.jpg
http://www.playwares.com/xe/files/at.../screen001.jpg
http://www.playwares.com/xe/files/at.../844/006/1.JPG
http://www.playwares.com/xe/files/at...844/006/32.JPG
http://www.playwares.com/xe/files/at...822/006/32.jpg
http://www.playwares.com/xe/files/at...fbd73971a7.jpg
http://cfile9.uf.tistory.com/origina...4A97FB421E74A2
http://cfile5.uf.tistory.com/origina...4A97FB4520B930
http://cfile1.uf.tistory.com/origina...4A97FB4721A30A
http://cfile23.uf.tistory.com/origin...4A97FB4822FF56
http://www.playwares.com/xe/files/at.../666/006/2.jpg
http://www.playwares.com/xe/files/at...6/IMG_5464.JPG
http://www.playwares.com/xe/files/at...7/IMG_5599.jpg
http://www.playwares.com/xe/files/at...7/IMG_5633.JPG
http://www.playwares.com/xe/files/at.../screen009.jpg
http://www.playwares.com/xe/files/at.../screen011.jpg
http://www.playwares.com/xe/files/at.../screen012.jpg
http://www.playwares.com/xe/files/at...126/007/12.jpg
4.2ghz P95 on the i5 looks sweet. Wish I could afford to jump ship...
i also have finally my i5 setup :)
http://i164.photobucket.com/albums/u...r/SDC10067.jpg
overclocking time :)
Please, what does it means PCH 1,8 and PCH 1,05 voltages...
Can you give me the value to higger fsb (dry ice)? (around ???)
Is this the IOH and ICH Voltage?
200 X 21
Dry ice -60
I am setting
CPU volt 1,4
VTT 1.3
PCH1.8 1.82
Ram 1,70 (3 x - 1200)
PCH 1.05 - 1.15
all settings in cpu config disable
I know itware, have to get higger using msi software, but the bios freeze and the systems can t enter in the windows.
I am using a GD65 (MSI)
I think there are something wrong with this MB :(
The only voltage i am not sure is PCH1.8 and PCH1.05
I did try load line enable and disable
Green power all disable/off
QPI Ratio 16
PCI ex 103 (i try 105, 101, 110, 113... ...)
Auto disable pci frequency disable
Anyone have one idea...i think i have to give up
Thanks for all ;)
