Originally posted by sandman
If the block was that hot, is there any risk of it mishaping at all?
Sorry, I'm a newb.
:) Your answer is on page one of this thread, here is a quote...
Originally posted by bowman1964
always flatten the base of the evaperator after brasing and not before.because it will warp slightly during the brasing process so flattening the bottom before hand would be a waste of time.
i usally remill mine ,but a good flat file ,and then hand lapping with 240grit,then 400 grit,then 600 grit..then polish with compound will give you the best possable surface..
small tip guys....get a small piece of glass(out of a old picture frame works nice) and place your sandpaper on it.this assures you have a perfectly flat surface ,since 99% of all glass plates are very flat.
