lol sorry mate
slaps myself :D
Just open the .bat file and check necessary commands and use Rivatuner.exe as interface to control the vgpu voltage, you don't need that fancy UI.. just apply commands to command line and change voltage with different hex-values :up: Works fine with GTX 260 Lightning and GTX 275 Lightning
i dont need it any more
would have been handy for the comp thought instead of being stuck at 1.3v hehe
would be interesting though if it could be adapted to GTX285s there and see what these babies can do with 1.6v through the core heheh
Some tasty leaks ;)
New software on the way, developed in cooperation with MSI special for Lightning series:
http://s42.radikal.ru/i098/0909/63/a2689cb414fa.png
http://forums.guru3d.com/showthread.php?t=304325
no memory voltage adjustment
thats disappointing :p:
What about Asus 285 TOP with UP6208? ;)
Same as the EVGA Voltage Tuner...
Some GPU's have the ability to adjust the core voltage, if they have the right chip on the GPU...
295's can... 280's can... not 285's! Wrong voltage controller chip.
http://forums.slizone.com/index.php?showtopic=33874
I have yet to see a program that could alter the memory voltage, even on the 280 and 295's.
Thanks for the info on the Asus 285 Matrix. I didn't know those 285's could. :cool:
We still are only talking about controlling the cores voltage, not the memory correct?
I can confirm that the script works for the Asus Matrix GTX285. :D
http://www.xtremesystems.org/forums/...d.php?t=234082
Don't know about the TOP, could je run 'rivatuner.exe /i2cdump' and send me the generated .txt file?
hey nice soft, can you upload SLI script again?
NICE Work
v-mem of this card in 1.75V and can stable on 2400mhz but Asus GTx260 Matrix`s V-mem is 1.91 and can increas to 2.1V but with stock V-mem(1.91) can stable on 2500MHZ easily! memory of these card in exactly same chip! Now have you any verison for v-mem of msi gtx260 lightning?
Hi Guys
This software works Nice
At this picture:
http://overklokken.info/images/MSI_G...260gtxmods.jpg
for V-core but for ocp mod Just Total IMAX mod is enough? or PER CHANNEL mod shoud be do?
tnx
dose this work with other 260s?
