Originally Posted by
Utnorris
Actually, if he uses the Typhoon 3 he won't. I went from 2 x MCP355's with XSPC tops, one in a GPU only loop and the other in a CPU only loop, both with a Thermochill PA120.3, to the new Typhoon 3 which is just a res and MCP655 pump for dual loops and just in leak testing I can tell that I am actually getting better flow than I did before, even with the pump set to just 2 or 3 on the speed control. Seriously, it is a pretty sweet unit.
But again, the main issue is getting it to switch on with each side. I just had a thought, don't do the relay, just do a toggle switch that will turn on the water cooling separately from the systems. That way you don't need to worry about the relays, resistors and what not. You sit down to the computer, flick the switch and then turn on whichever system. Turn on the thermal shutdown in each of the bios just in case you forget to turn it on and you should be safe.
