If any of you guys needs a translator, just shout! :D
those overclocks are just sick!
amd, if you are reading this, i would give you my left nut for a TWKR
Sick benches Chew* + Donbe
Looks like alot of fun to be had :up:
chew* awesome results as always
Video timestamp 1:48, we managed to catch the WW run live. I had the camera, and I think this shot was my sole contribution to the footage.
http://links.amd.com/XTREMECONDITIONSHD
Chew*
Nice Results
Especially intrigued how you managed to push it to 5350MHz on DI. You broke your 5.2GHz Dry Ice Theory
I wish I had one to play around with for my next DI run.
Keep it up.
Thought i'd mention resolution was not default.....some bug with XP...driver and my monitor....bench more or less run to show 3d passed at XXXX cpu speed........vista works fine however......will try a vga cable to see if bug goes away....according to CCC I am using 1280x1024......06 seems to default to that...
Nice result you got there, what's the different with TWKR and 955BE ??
Higher default clock with lower vcore?
Yep, that video was sick, as well as the transparent pot! :D
I am kinda jealous that the big dogs get all the killer gear, but I'm sure they make it shine more than I ever could... :yepp:
Water cooling is about as hard core as I've gotten so far.
Great results guys!!! I can't help but think all this tinkering is only gonna help end users... Plus, it's alot of fun to watch. :up:
Gratz to the lucky few! Keep on tweaking, and keep the numbers coming.. :clap:
chew*-san
I did not like much MSI.:p: However, I chose it because it was MB which could easily perform Quad-CF.
Is it NB-Freq? If it is it, I think it to have been 4350MHz.
mcbalaban-san,Thank you.
Machigatteitara Osietekudasai :p:
ridney-san,Thank you ;)
There was announcement of TWKR in AMD-JAPAN yesterday. I was going to demonstrate in GD70 board and 4*HD4890 TOXIC, but GD70 board has broken.:(
that clear pot is just sick. i would love to go to one of these events, but im scared i might get a new hobby and i cant afford the current ones.
The clear pot will once again be finding its way into my hands in the very near future :)
Here we go.....still have yet to find a solution.....either drivers or future mark are not cooperating......as you can see the monitor supports it and is set at default of bench...
Welcome to suggestions. Works fine in vista and win 7. VGA and DVI tested....
http://chew.ln2cooling.com/qdig-file...WT/lrg_bug.JPG
http://chew.ln2cooling.com/RKWT/bug2.jpg
No easy fix to the issue......swapped back to my 19".
Someone told me it would be 2k less score.....
I highly doubt that since once you hit 6.2 all cpu bottlnecks are gone on 2 gpu's total ;)
Having hit a cpu speed of 6390 3d06 at the Austin event I gained a whopping 300 points from 6200 to 6390 with cards @ 1000/1165 for a total of 34,3XX .........with 2 x 4890's
Tested real quick in res.........canyon shows only gain.......the rest are variations in 2 sep bench runs at best.
http://chew.ln2cooling.com/qdig-file...g_1280x800.JPG
http://chew.ln2cooling.com/qdig-file..._1280x1024.JPG
Hope this clears everything up
If not this should........
TWKR with Higher GPU clocks that actually work.......versus software that people think is working "properly"
http://chew.ln2cooling.com/qdig-file...203d%206.2.JPG
AUSTIN Higher CPU speed and lower GPU clocks because higher clocks were NOT working with software correctly.........
http://chew.ln2cooling.com/qdig-file...%20animals.JPG
Once again we can see canyon was boosted ONLY........canyon also gets a boost from GPU core clocks........
You should get the new CPUz version that detects TWKR....
Aircooled chip ... nice handpicking from AMD , i tried some 955 and i can get the 2k6 @ 4ghz with a so low Vcore :)
http://www.pt1t.eu/public/AM3/TWKR/t...air_1%2C3V.png
