where would i get one of these?
http://www.newegg.com/Product/Produc...82E16819103681
the egg has them and it appears that most boards can really push the bus speed on them
http://img.techpowerup.org/090619/Capture091.jpg
would try for higher on my M4A78T-E but that met an untimely death as of recent got a crosshair III in the mail will try for 500mhz HTT when it comes in
i mean the
Msi 770-c45
can you add bios voltages screenshot? liki this one?
http://images.bit-tech.net/content_i.../msibios1s.jpg
i can't increase cpu vvd voltage more than 1.35V :( also i don'y know best voltage for NB to work with athlon II 250 at 3.8-4.2Ghz.
MSI has updated the BIOS for the 770-C45 to support the new X6!
MSI 770-C45 BIOS PAGE - MSI 770-C45 CPU SUPPORT LIST
BIOS v1.9 (2010-05-18)
- Support AMD 6 core CPU.
- Improved memory compatibility.
Cell Menu - BIOS 1.9
http://img541.imageshack.us/img541/5...0c45bios18.png
Hmmmm it doesn't look like it has the option to unlock a 960T to a X6.
