Would be better with 2x 3.0 pcie16x slots.:up:
I like what I see... those should finally let the Opteron's Breath. Full support for HT etc.
Anyone know if the new chipset will enable crossfire in multi-socket variant?
http://en.wikipedia.org/wiki/AMD_700...t_series#790FX
790FX is a dual-socket chipset, so with the new chipset Crossfire features should be there if the motherboard manufacturers wants it too?:shrug:
The existing Nvidia MCP55 Chipset Motherboard offerings from Super Micro are able to run SLI so the answer would be yes. That is the board that I would buy if I needed to buy one now.
http://www.supermicro.com/Aplus/moth...55/H8DAi-2.cfm
Remember, this is all new stuff so you will see a slow gathering of steam while they roll out the new stuff and I imagine they want to make sure the boards are good for the 6 socket chips..
As Brother Esau said above this board will handle the 6 core cpu's and is SLI capable..
The nVidia chipsets even as old as the 3600 did SLI, but that doesn't really say much as to if AMD plans to keep Crossfire capability in RD800S/RS800/code-name-of-the-week from the desktop version it is related to.
AMD will not allow for vanity sakes SLI on Server/Workstation Motherboards and not CROSSFIRE it just seems improbable that they would permit that.
But if the chipset allows it (as the 790FX actually does...) it's all up for the manufacturer, and I can't see how AMD would have an issue with that.
Also GPGPU is the new thing, even for certain server/workstation apps so the chances of a Dual-Socket Crossfire Motherboard seems very likely to me with the next generation of chipsets.
I don't think that's what he's saying. Even if available from the chipset, a board maker may choose not to support it unless it is a minimum requirement feature for that chipset.
is socket G34 only 2 socket or will there be some 4 socket boards ?
G34 is for 4 socket, and it has lower end 2 socket boards. I cant remember the name of the other socket coming out that is for 1 socket server, and has higher end dual socket boards. The 2 new sockets overlap in the 2S area because thats where the most sales are from.
Technically, does the board manufacturer need to officially support crossfire? If the chipset allows for it, and you install the drivers for it then it *should* work. right? I thought the cards communicate through the crossfire bridges on the cards themselves...
I imagine there's probably some BIOS component that's required, but I don't know for sure.
http://www.newegg.com/Product/Produc...82E16819105255
Newegg has finally listed. $499 Should I go ahead and get two? I get paid about the same amount today anyway. :)
Get 2 and cheap board to hold you over in till new chip set.
And also showoff 12 cores :)
OH man the fact these things are not $1,500 made me actually pause for half a second and ponder building a system out of two of them lol. Good thing my mizer side is stronger than my nerd side...for now...while I have a few months left of paying off the last student loan (which is my only remaining debt). haha
I wouldn't mind getting one of these and finding a board that will OC and see how it does....just to get an idea if they released a desktop version;)
Yep, wait a month or so and then see what wonders await you.
