There's some here
http://www.watercoolinguk.co.uk/cata...x.php?cPath=98
I heven't used this so I don't know what the quality's like.
There's some here
It's so gorgeous that I'm textless (speechless) lol.
yeah, thanks i was looking at this stuff when i was ordering my components but didnt know what it was like....ended up gettin AC ryan stuff and i shall never buy their stuff EVER again, but we learn for our mistakes eh??
I shall have to have a look at Murdermod when i get back form my holiday to kazan. if he hasnt put it up still then ill order that stuff and have a go at it ill..... when i get back i want to see ur build complete!!!! be back next monday.
bye
exe
:up:
I've got all the hardwired cables done now,I need to move the plugs on the SATA power cable before I can finish the modular cables,I had hoped to take the braiding right in to the PSU but as you can see it's so tight in there with those heatsinks there just wasn't the space for that volume of braid,so I had to just heatshrink the ends of the bundles,even then it was a struggle to get the cover back on
http://i296.photobucket.com/albums/m...Picture017.jpg
http://i296.photobucket.com/albums/m...Picture019.jpg
With the cover back on
http://i296.photobucket.com/albums/m...Picture022.jpg
http://i296.photobucket.com/albums/m...Picture023.jpg
8pin Pci-e
http://i296.photobucket.com/albums/m...Picture026.jpg
http://i296.photobucket.com/albums/m...Picture027.jpg
24pin
http://i296.photobucket.com/albums/m...0/DSCF2602.jpg
http://i296.photobucket.com/albums/m...0/DSCF2601.jpg
All of them together
http://i296.photobucket.com/albums/m...Picture020.jpg
PSU fitted in case
http://i296.photobucket.com/albums/m...Picture032.jpg
And plugged in
http://i296.photobucket.com/albums/m...Picture039.jpg
http://i296.photobucket.com/albums/m...Picture037.jpg
http://i296.photobucket.com/albums/m...Picture034.jpg
http://i296.photobucket.com/albums/m...Picture040.jpg
Just need to even them out a bit now.
Looking great mate!!
All that white in black makes this buikd gorgeous
how u liken that XSPC CPU block?
Outstanding work! :up:
Your sleeving job is pure perfection. :)
Thanks for the comments,they are appreciated :),Just a small update,I got the HDD's and DVD drive fitted,here's the HDD's
http://i296.photobucket.com/albums/m...cture002-1.jpg
They're going in the two 5.25" bays below the res's so i'm using these mounts
http://i296.photobucket.com/albums/m...cture006-1.jpg
http://i296.photobucket.com/albums/m...Picture009.jpg
Here they are fitted
http://i296.photobucket.com/albums/m...Picture011.jpg
http://i296.photobucket.com/albums/m...Picture015.jpg
And fitted in the case
http://i296.photobucket.com/albums/m...Picture018.jpg
http://i296.photobucket.com/albums/m...cture019-1.jpg
http://i296.photobucket.com/albums/m...Picture024.jpg
I moved the plugs on the SATA power and sleeved that aswell
http://i296.photobucket.com/albums/m...Picture028.jpg
http://i296.photobucket.com/albums/m...cture034-1.jpg
Plugged in
http://i296.photobucket.com/albums/m...Picture036.jpg
http://i296.photobucket.com/albums/m...Picture041.jpg
That's all I've got for now,untill next time :)
Every time I see that white tubing, I want a glass of milk. Your build does a body good.
Not to be nit picky or anything, but is that top HD got a good connection with the sata power plug? It looks like there is a lot of tension in that photo :shrug:
Great as always besides that ;)
I thought i'd have a break from sleeving and had a play around with the LED's for the res's,I tried the white ones first
http://i296.photobucket.com/albums/m...icture005b.jpg
They don't look that clear and have a slight blue hue,next up UV LED's
http://i296.photobucket.com/albums/m...Picture008.jpg
Personally I think the UV looks better,what do you think?,comments welcome :)
Where you going to use UV reactive fluid? Even if you weren't the UV LEDs add a nice touch of color. In that photo it seems that it almost matches the fan controller :up:
The res's are full,Feser Clear UV Blue,if you look closely you can see a small air pocket at the top,i'll take a couple of night shots tomorrow with the pumps running for comparison.
I like the UV's better, but i guess it also depends on the liquid effect once that's in...
pure project is very nice and clean. :up:
id go with the UV ones, they are a closer colour the the LED's in your fan controller...and if u have some nice UV liquid in there it would ping!
cant wait to see more progress
:up::up:
Just a small update,these are the modular molex cables,there are two of these
http://i296.photobucket.com/albums/m...39aaMedium.jpg
Plastic stoppers and plugs removed
http://i296.photobucket.com/albums/m...e003Medium.jpg
Heat shrink on all the ends
http://i296.photobucket.com/albums/m...023aMedium.jpg
With the plug fitted
http://i296.photobucket.com/albums/m...025aMedium.jpg
http://i296.photobucket.com/albums/m...24aaMedium.jpg
Sleeved and aditional heat shrink over the join
http://i296.photobucket.com/albums/m...026aMedium.jpg
http://i296.photobucket.com/albums/m...e011Medium.jpg
And the PSU end
http://i296.photobucket.com/albums/m...e013Medium.jpg
I did the front audio/usb cables aswell
http://i296.photobucket.com/albums/m...020aMedium.jpg
I'd also like to add,this build is now sponsored by MNPCTech,Bill has kindly donated some of his 120mm Machined Billet Computer Fan Grills
http://www.mnpctech.com/120mm_fangri..._mnpctech2.jpg
http://www.mnpctech.com/120mm_fangri...m_mnpctech.jpg
I'll be powdercoating these and using them to replace the basic wire grills I have now,I think they'll improve the overall appearance of the case.that's all i've got for now,untill next time.
very nice
your sleaving job looks really nice and clean i like the look a lot cant wait to see the finished product:up:
Thanks rjkoneill :)
Thanks STRMX :)
Just a small update,the SATA cables that came with the board were a bit short so I got some 1m ones
http://i296.photobucket.com/albums/m...e009Medium.jpg
So I sleeved these aswell
http://i296.photobucket.com/albums/m...e015Medium.jpg
Heat shrink before
http://i296.photobucket.com/albums/m...e018Medium.jpg
http://i296.photobucket.com/albums/m...e022Medium.jpg
And after
http://i296.photobucket.com/albums/m...e021Medium.jpg
http://i296.photobucket.com/albums/m...e023Medium.jpg
And fitted
http://i296.photobucket.com/albums/m...e055Medium.jpg
I also got the 120mm Machined Billet Computer Fan Grills from MNPCTech
http://i296.photobucket.com/albums/m...e050Medium.jpg
http://i296.photobucket.com/albums/m...e052Medium.jpg
I had planned on powdercoating the surround white,but when I seen them they look really nice so I decided to keep them as they are,here they are fitted
http://i296.photobucket.com/albums/m...e063Medium.jpg
http://i296.photobucket.com/albums/m...e076Medium.jpg
http://i296.photobucket.com/albums/m...e079Medium.jpg
http://i296.photobucket.com/albums/m...e080Medium.jpg
http://i296.photobucket.com/albums/m...e089Medium.jpg
And with the fans running
http://i296.photobucket.com/albums/m...e028Medium.jpg
http://i296.photobucket.com/albums/m...e012Medium.jpg
http://i296.photobucket.com/albums/m...e017Medium.jpg
I think these look much better than the wire grills
Also I got Mod of the Day over at HardOCP,which I didn't expect :),anyway that's all i've got for now,i'm hoping to get all the wiring finished at the weekend.
Those grills look so nice against the white, I have to say there are a lot of great builds on this site, but I think this is one of the best, purely because it is so clean and simple. Congratulations on a great build so far!
Wow, that last update looks amazing!! i love the colour of the lights in those fans, looks like they where built just to match your case! very very nice indeed, the grills look really good, i like them with that brushed silver effect, gives a lovely depth to it! cant wait to see it fully completed :up::up:
i love the way you have managed the SATA cables going into the hard-drive looking nice and tidy
this build really is looking stunning :yepp::yepp: keep up the good work
