mpressive BCLK
good job :clap:
mpressive BCLK
good job :clap:
I own a P6T WS Pro as well..
Could you please post your BIOS settings for this overclock?
Also, what do I need to increase in order to get higher BCLK speed? The QPI voltage?
It seems I can't get higher than 170-175 BCLK speed.. if even at 175 the system is not stable
I've tried QPI voltage 1.25-1.3V... I didn't try 1.35V yet because it becomes pink color.. at 1.3V it is still yellow. Should I try 1.35V ?
Boot in bios on 200x low multi with loose timings on the ram, this should work ok.
