wow sweet run sampsa :toast: i am just missing the 3rd pci-e on this board - everything else looks perfect. now get the LN2 truck at your bench room and hunt the 36k :D
great sampsa
for SLI tests I'm going to use my Asus M4N82 Deluxe motherboard which is based on nForce 980a chipset :)
I already did Vantage CPU air cooled:
http://www.xtremesystems.org/forums/...d.php?t=224569
Sampsa is first time that AMd have a serius mainboard and chipset, sin however, that to do Sli and Crossfire on AMD currently need two different mainboard......this is only limit.....but not necessarily Asus product this mainbaord in future :D:D
Good CPU and work :up:
Sampsa, can you tell me if this board has Load Line Calibration or Voltage Damper option in bios?
These ROG boards are truly impressive. Nice results Sampsa!
Sampsa u rule man.
You just made me go for crosshair and 955 instead of i7 :)
Nice job Sampsa...36k is waiting for you. :D
sampsa, I wish you good luck with todo list :)
Very nice first runs Sampsa! :toast: So close to 36k :p
Must have been typo, i have never seen higher than mid 70k range result. My goal one day is to break into high 80k :D
Score to beat: 71034 - http://hwbot.org/result.do?resultId=853040 :D
Any idea when this will be available in Canada?
