Absolutely breathtaking! ThaT cl6 is total geek pr0n!!
Great Job! Amazing GT kit
This is truly stunning :shocked:
Though it's a huge tease not telling us what the voltages were. (So that we can try this at home, of course :p:)
You can not try this at home. That's the catch.
Warning: Much of the results depicted and/or described on this thread are potentially dangerous. Virtually all of the results seen in the photos are from experienced cherrypickers. Do not attempt to duplicate any results that are beyond your own hardware's capabilities. Always wear the appropriate safety gear. And so on, and so on.
OK, let's see... :)
I think some of you may have hard time believing, but this is not particularly awfully "cherry-picked" GT kit. As some already mentioned, there is a lot of effort put into screening for 2000C7GT spec, and although results I show here may not be typical, that's what is so great about this product! When you think you already reached the apogee, all stars come to near perfect alignment and you end up picking your jaw off the floor in result :) I don't want to imply that everyone will be seeing those types of results during their bench sessions with 2000C7GT, as there are also other factors involved in this success. But rest assured, that Dominator GT will not disappoint - it's "the one to rule them all" after all, right? :D
You asked about voltages... Actually, dinos22 was very close in his speculation, let's keep it at that for now :D There is also very low ambient temperature involved in this experiment as well... :D
Thanks for the good words and your support guys! :up:
so DHX TEC ram cooler wasn't used ? come on voltages so we can try this ourselves hehe
i think 2,1vram and 1,7/1,8 vtt lol
Bachus
- AMAZING RESULTS! You sir, make me remember all the fun that memory tweaking can bring again. Just jaw dropping results, I am floored. :up: When I saw the press release, I knew it had to be you manning the controls. :D
Why would you doubt that? Maybe not intentionally, but by binning the cores themselves, and ensuring the best silicon from each wafer is used in the creation of each 975, you are in a sense binning the memory controller as well.
Remember the S939 FX chips? Always had the best memory controllers. Granted, you could always get lucky and find a 3200+ with an equally good IMC, but your best bet was in the FX. :)
that is nuts
damm last set up i overclocked was ddr1 im so behind .
i think im going to buy there tec cooling and add on my 3 tec coolit eliminator
then lean to overclock again
can you guys post your setting im going to give it a go when i get my rig
:shocked:
:worship::worship:
Masta :)
Nice CPU and ... Mems :up:
Incradeble GT's. :clap:
CL6 is really :banana::banana::banana::banana: great!
George,
No, for those tests our Ice Series T30 was not used.
OK, I will be more specific this time:
1. The CPU I was using does not particularly like anything above 1.65V VTT (Uncore) Voltage. It just flat out either locks up or causes the system to not boot at 1.70V.
2. VDIMM... Well, briefly I looked at 2.10V, but not much benefit there... So, now you all more-less know where I stand :D
Damn dude, you don't want me to blush, do you? :lol: Seriously though, I appreciate it!
It's still going...
Thanks a ton! :)Quote:
Excellent results as always from Corsair. You just keep getting more and more popular at my list of favorite brands...
If you could just send me one setup like to for being you fan, you would even top google :P
Heya Tomek! Dzieki (Thanks)!
Another fellow Polish comrade :D Thanks a lot! Means a lot to me that the news reached my homeland as well :up:
How were they cooled then?
if your binning the cores then you dont bin uncore or the imc... intel has never binned imcs, ever... and they havent binned uncore and imcs on i7 so far, so what makes you think all the sudden they will? they havent said anything in that regard, nothing at all, so why should they suddenly do something diferent?
they had imc and uncore both locked to the core clockspeed and running off of vcore and vdimm, so in that case its possible that by binning for the best cpu cores you end up binning for a good imc as a side effect, for i7 and phenom and phenom2 its diferent...
thanks for the info or what little of it you gave LOL
With Corsair GT 2000Mhz 7-8-7-20 from Corsair, I'm still hovering around DDR3-2160mhz 7-8-7-20 1T for 8x 32M pi, DDR3-2208Mhz 7-8-7-20 1T 32M pi and DDR3-2286mhz 7-8-7-20 1T for validation/1M pi for air cooled ram and i7 920 cpus - working to push higher :D
Corsair Airflow but ambient temperature is not your room temperature ;) :)
Yes, I am :toast:
Hehe, oh come on, I gave a lot :) - VDIMM below 2.10V, and VTT up to 1.70V. But reaching anything higher than great clocks you already accomplished (especially for 8x32M), without resorting to sub-zero CPU cooling is going to be very difficult on Core i7.
Wow, amazing man! Congrats!:up:
It's the time change my magic D9JNM's...:)
Some helium could be interesting :)
Thanks Bachus
impressive results.. any CL5?
