I'll try to test with LN2 on upcoming weekend if there are any left after me & SF3D will run our MOA 2009 Europe qualifying runs :)
And we want broke in cpu-Z 7GHz ;):up:...
Very nice work...and as you can see there remains much to be done. Vince was able to do amazing work, but there are new challenges...
Was just playing around sampsa, wasn't trying to beat you , more or less wanted to know what the handicap is for ATI in vantage So i was using your scores as a reference.....Looks to be about 500mhz....if you can push the cards hard in multi card configs.
On a side note I have no problem Ocing in vista 32 :shrug:
Been a very long night and the poor seasonic 500w is crying for mercy now.......I'm off to bed...
Looks like I got my work cut out for me......
http://members.cox.net/wmdieselmc26/...%20vantage.jpg
Hi Sampsa, k10stat working on nvidia chipset?
Well at least they are scaling 3 to 4 card decent in vantage....I get the feeling they need to work out some kinks with the drivers though based on some of the higher frame rates I was seeing in test 1 at specific locations in tri versus quad.
It's a tad hot today, had to back off the cpu a little.
http://members.cox.net/hoobahans/3x4890%20vantage.jpg
If it’s ok I thought I would post up my Vantage results for comparison? I’m running the same MB with Evga GTX 260’s in tri-sli. I’m at best just an average overclocker so I’m sure there is more to be had from my hardware in the right hands but this is where I stopped for the time being.
CPU is water cooled but the GFX cards are air cooled.
http://i262.photobucket.com/albums/i...controlpan.png
Hmm.. I haven't installed Vantage yet.. it is soo boring :P Sorry.. i hate long benches :) I will report back on what I get too.
- Ton
ps - Seems Zolkorn has the AMD Vantage WR @ 24k with 3x4890 and 955 @ 5.5Ghz.
BTW there is a couple of bios updates for the board improving memory stability and cpu full load heat
awesome, still sad no other 980a's are out but good stuff!
Has anyone else using this motherboard noticed that when setting the Bus Speed in the bios that you don’t always get the number that’s typed in? I set 204 but the bios sets 202, I type 206 then the bios sets 204, 208 or 207 and get 206. I’m using (if I remember correctly) the 704 bios.
Anyway I tested a little more today and this is the best result I have had with this combination to date.
Vantage PhysX disabled CPU @4125MHz
http://i262.photobucket.com/albums/i...sxcpuzgpuz.png
I have a set of Evga GTX 295 reds coming in this weekend... i will run some benches soon.
We raised the bar preety high, dont think AMD vantage record is gonna be doable on air now ;) not even with nvidia......Totally expect samspa to whoop my ass though :D
http://chew.ln2cooling.com/satbenchsession/7.jpg
wow looking at this stuff making me o/c again hopefully my DFI LP(forgot model #) board will do some good
Undoubtedly a lot of work behind those numbers chew, great score.
I spent alot of time hacking the bios on the cards....third party software clocking has glitches and performance issues......impedes the score by alot......
We're gonna give it another go and see how much of a run we can give the intel guys soon, wasn't maxxed out.
Hopefully my 6.1 gig chip is up to the task in vantage next round.
Well done chew*, the bar is pretty high now. Was it easy to do 5.6Ghz for Vantage?
