good stuff martin, i love the GTs too :D ...i wish it were quieter..lol
thats why we have lots of rads :D double your rads if possible :)
According to this, they make up to 1,850RPM which is rated for 98m³/H at 28dBA: http://www.scythe-eu.com/en/products...on-120-mm.html
I want a really silent fan, I have been thinking about the S-flex E (1200rpm) I have had one and i know it is very silent. But then i saw this test with the Gentle Typhoon showing very good results. Would you recommend it over the s-flex?
And I know that fans sound more the older they get. Have you been using new fans or used fans?
http://www.scythe-eu.com/en/products...-case-fan.html
There is also a difference in sounds. Not just db. Some noise is worse than others. I know vapor said that the sflex sounds nice. Probably because of the
S-FDB (Fluid Dynamic Bearing by SONY Corporation) i think. I'm buying 10 s-flex E next week but now you got me unsure, DOHH! Maybe I should go with the GT...
Info from scythes site:
Gentle Typhoon 120 mm Fan
(500 rpm - 800 rpm - 1,150 rpm - 1,450 rpm - 1,850 rpm)
Technical Data:
500 rpm: 0.015 A - 5 dBA - 31 m³/h
800 rpm: 0.023 A - 9 dBA - 48 m³/h
1,150 rpm: 0.034 A - 16 dBA - 63 m³/h
1,450 rpm: 0.049 A - 21 dBA - 85 m³/h
1,850 rpm: 0.083 A - 28 dBA - 98 m³/h
Bearing Type: Double Ball Bearing
Accessory: 4-pin Molex Adapter, 4x Screws
MTBF:
100,000 h / 35°C or 60,000 h / 60°C
*1,850 rpm Model 55,000 h / 60°C
Model Number:
S-FLEX SFF21D (800 rpm)
S-FLEX SFF21E (1,200 rpm)
S-FLEX SFF21F (1,600 rpm)
Specifications:
800 rpm Version: 33.5 CFM = 58 m³/h | 8.7 dBA | DC 12 V | 0.10 A
1,200 rpm Version: 49.0 CFM = 83 m³/h | 20.1 dBA | DC 12 V | 0.15 A
1,600 rpm Version: 63.7 CFM = 109 m³/h | 28.0 dBA | DC 12 V | 0.20 A
1,900 rpm Version: 75.0 CFM = 127 m³/h | 35.0 dBA | DC 12 V | 0.24 A
Connector: 3-pin (4-pin adaptor included)
Cable Length: 30 cm / 11.81 in
Bearing Type: S-FDB (Fluid Dynamic Bearing by SONY Corporation)
MTBF: 150 000 hours
You tested the 1850rpm variant right? Do you have a graph on specific rpm at volt? And have you tried push/pull in noise difference?
I wounder what happens if you make a blade swap with s-flex and GT :D
Edit: I also found this the other day
http://www.techpowerup.com/92728/Scy...ries_Fans.html
To bad they didn't release a 140mm model
Most of the fans are new with the exception of the UK3, Yate Loon LED, and Yate loon SL-C. The UK3 I've used for radiator testing only, the yates, I've had in use off and on. All the others have had less than a couple of hours on them.
I agree on the noise. dB is a measurment of sound "Quantity" and that does not necessarily relate to "Quality", that's only something you can really judge by ear, and different for every one person.
I've updated the charts in the OP to include the RPM data. The GT I tested was the "AP-15" version which is the 1850RPM spec version, although mine only tested out up to 1740RPM on the radiator. RPM specs are only approximate numbers is what I'm finding, some are WAY off too.
Not sure you could swap blades or not, I believe the GT has a unique motor to handle the extra blades, so that may not work out in the end anyhow.
Anyhow, I've update the OP with some better charts.:up:
Here is a "test" that a member (zgundam) from silentpcreview did:
http://www.silentpcreview.com/forums...b930a287030365
And also, Do you know if it is possible to remove the blades from the motor? Or if it is something special. Because that gray color is ugly as imo and i would want to repaint them.Quote:
Update: Done some quick tests of the fans. I don't have any expensive airflow or sound-measuring equipment, so my opinions will be somewhat subjective.
Both 1450rpm and 1850rpm fans were tested at 12v and 7v (using this kind of fan adapter), with a Corsair HX620 supplying power only to one fan at a time and nothing else. Room was completely quiet (no car noise, etc). Tests were performed in open air with no obstructions within 30cm behind or in front of the fans, in vertical position. Two distances used to measure fan - about 10cm and approx 50cm from my ear to fan hub. I did a quick comparison between these fans and a 1200rpm SlipStream and a EbmPapst 4412 FGMLL.
The 1450rpm was surprisingly quiet (but not silent) at 12v. While at 7v it wasn't completely silent, giving a very low continuous hum, noise character it's probably comparable to the 1200rpm SlipStream at 7v. Airflow could probably be compared against a EbmPapst 4412 FGMLL @ 7v.
The 1850rpm Gentle Typhoon was noticeably louder than the 1450rpm version at both 12v and 7v, but not annoying. Airflow felt comparable to a 1200rpm SlipStream.
Both fans have very unique noise signatures (really don't know how to describe, sorry) which I haven't heard from other fans so far, but it's definitely very easy on the ears.
To summarise, the Scythe Gentle Typhoon seems to be a serious competitor for (at least) the 1200rpm Slip Stream. It's got a high MTBF, costs the same as a Slip Stream (at least in Japan anyways) and, from initial impressions, very quiet with good noise character. I just wish Scythe would start distributing these worldwide asap so I can get them cheaper!
Will see if I can get some audio samples done (assuming my mobiles' crappy mic is up to it), but I'd be happy to submit both samples to SPCR for proper testing (as long as I get them back in one piece. and working of course. Razz) if they're interested?
The GT really wipes the floor in your test. It is good across a big range also 700rpm - 1800rpm. I wounder why no one had noticed this before? I'm sure i have seen a picture with someone using them on 2 rads stacked between each other.
Anyway, I did some more searching and found this. Its in French but google translate makes a pretty good job translating it.
http://www.rexware.fr/index.php?opti...=1013&Itemid=2 (in case my link from google.se don't work)
He only got the 1150 model down to 878rpm at 5 volts. And you got your 1850 down to 700rpm at 5 volts (behind a rad though). That would mean that there is no reason to get a lower rpm variant if they don't sound less at the same speed.
http://bankti.free.fr/gty3.gif
Welcome back Martin!:welcome:
Yeah, it's still a tough call even having both sitting here in my hands. The sound quality of the SFlex-E is very good and it gets way down in the RPM range if your after total silence.
Great links, at least I'm finding some consistency even though I measured on the fan edge mounted to a radiator and they measured open air inline with the motor axis.
I'd like to try some of the other RPM ranges just out of curiousity. I find it interesting how the different RPM ranges of the same fan lines produces very different results. My Sflex-E and Sflex-F preformed relatively the same regarding cfm/dB ratios, but the Sflex-G was different. I guess I always assumed it was the same fan with some very simple modifications, but after reading some of the fan development notes, it appears they design the motor specifically for different RPM ranges, etc...so they really are different fans despite looking the same.
Anyhow, I'm still trying to look through all this data myself and make sense of it, feel free to draw your own conclusions or if something seems out of place, I can always make another run to check.
Thanks!
Martin
I really appreciate the tests you are doing here. Up until now I could have sworn that the S-flex was the best fan, no doubt. But now your test beg to differ.
The thing I'm looking for is silence and good performance. I rather sacrifice performance for noise than vice versa. But looking at your graps it seams that the GT beats the S-flex series. It have a wider rpm range and have better noise/airflow ratio.
The s-flex E moves the same amount of air at 9V as the GT does at 6V. At 9V the E does 920rpm (56db) while the GT does 880rpm at 6V (53db). Looking at these numbers again I notice that there only is small numbers separating them both. And with the S-flex you get 50 000 hours more lifetime. It really is a tough choice. And the S-FDB (Fluid Dynamic Bearing by SONY Corporation) is really nice that the S-flex have.
How much difference does 3db actually make? And do you have any idea when you will be able to get your hands on some GT in the lower range?
"The sound quality of the SFlex-E is very good and it gets way down in the RPM range if your after total silence." But at 350rpm with a radiator there must be no air coming through at all?
Haha! There they are :D
Satisfied with you GT's?
Basically, what I'm trying to decide is S-flex < GT or vice versa.
So I'm asking you, Is the Gentle Typhoon the answer to life the universe and everything? Or is it still 42?
One more thing, have you tried to remove the blades from one of your GT's? Is it possible? A thousand questions as usual... Typical of me :P
i have the scythe flex G, and the gt 1850s, the scythe flex g is has a higher pitched noise at 12v, the gt @ 12v is just right, but if you want quiet, the sflex f or e, or the gt 1600s might be better. but the less rpm the less noise.
the gt i would pressume have better motors :D
****only way to satisfy your curiousity is buy samples, thats what i did :D
i have been looking at two fans s-flex g and the GT's i want to paint them red and white proppellers
but the s-flex f is much lower cfm then the G and the gt's have double ball bearing compared to the bearing of the s-flex g
What is the advantage and disadvantage to both of these fans?
Does this sort of video recording work alright?
http://www.youtube.com/watch?v=dFpSYLO7Cns
the air is hitting the mic, there are many ways of measuring the sound, since mine is facing me, the fans don't make that noise on the intake...
my two cents.
thats loud i wonder how close your putting the mic(not really though, more like breeze)
Dang, that's what I was thinking too. The wife left the house and my daughter took and extra long nap, so I had about two hours this afternoon to record in pure silence (Something that almost never happens). I got about 20 of the fans recorded like this, but all of them have that wind buffeting noise problem. My POS video camera doesn't name files in any logical order, so I was hoping I could work up some sort of setup where you could see the model number. Oh well, I tried.
Here is the same failed setup for the S Flex-F
http://www.youtube.com/watch?v=O63YQiBCoAw
And the Yate Loon D12SL12-LED-S
http://www.youtube.com/watch?v=ip2AvaPu2AA
Who wants to do some good video recordings?
I've got a box full of fans, I'm ready to ship..:D
I think that you should try putting the camera so it doesn't blow air directly on the microphone. It would be better if you put some protection on the mic or so. You don't really need to hear that sound. Great quality though! :up:
i rather tired due to my exams so ill pass
hey martin have you ever considered testing the enermax magma's and clusters?
does the s-flex g have high pitched sound?
off topic but how much cfm should be passed through a rad ? (in pushpull?)
Martin,
Can you please check for static pressure of the GT Vs. Kaze Master Vs. S-flex Vs. YL-D12S @ the same RPM ?
I currently have 4 YL-D12SL On my Feser 480 and I am trying to conclude, what fan would be better, GT or Kaze Master (or stay with the YL).
The Kaze Master is 38 mm, so I really doubt the GT will be better.
Anyway, those are the main competitors IMO, so I think it would be wiser to focus on them an not on 30 other fans that obviously are not in the same league.
BTW.
It's great to have you back here !
