No offence, but I'd like to have a second opinion, or to put it correctly a second and/or third measurement on that. Before getting the values affirmed, I won't give you another resistance value for the vmod. I wouldn't like to have some poeple kill their cards due to bogus readings. Hope you understand. ;)
Your current readings are just way too different. First you say 7.4 (Ohms, as it was @20 Ohms range setting) or 740 Ohms (just not possibly at 20 Ohms range setting) and now it should be 580k (at 2000K range setting)? That seems odd and absolutely not believable. Either your meter is damaged or you are doing something wrong.
