i cant see the pic :( i have to get photobucket pro :(
Nah its me dude. I exceeded my monthly bandwidth limit. Will be sorted next week.
no it means that he has exceeded his bandwidth and needs to upgrade to pro in order for us to see the pics....you dont have to buy pro to see his pics :rolleyes: *edit damn beaten to it
Shame about the pics I was just looking through this and didnt get to the latest pics before they dissapeared - hopefully the will be back up soon :shrug:
Will be all sorted in the 7th. May look for somewhere else to host pics.
imageshack.us :)
Well i used to use them but i found photobucket better for some reason. I think iv got a spare photobucket account iv hardly use that i will re host all the pics.
Update.2 1st may.
My psu is basically fully braided bar a molex cable. This is nearly 40m of braid, 2m of heatshrink, 2 full rolls of insulation tape and alot of time and effort but its done finally....
http://i220.photobucket.com/albums/d...s/IMG_1960.jpg
http://i220.photobucket.com/albums/d...s/IMG_1961.jpg
http://i220.photobucket.com/albums/d...s/IMG_1962.jpg
http://i220.photobucket.com/albums/d...s/IMG_1969.jpg
Cheers.
is that from cable organizers?
Sorry i dunno what you mean?
lol sorry, did u order ur sleeving from cableorganizers.com? if not, whered u get ur sleeving from?
Nah its from my sponsor ChilledPc.
looks good man! keep up the clean work :)
Thanks duder.
Update 7th May.
Got some parts from my new sponsors:
Thanks Oggie for the P clips! will come in very very handy with cable management.
http://i220.photobucket.com/albums/d...s/IMG_2010.jpg
Thanks again dude.
And also thanks to PaulyD for a Thermochill PA120.3 shroud. Very very nice of you dude! Will be getting painted with the case!
Oh and thanks for Webbo for showing me these nice fans :)
http://i220.photobucket.com/albums/d...s/IMG_2001.jpg
http://i220.photobucket.com/albums/d...s/IMG_2002.jpg
http://i220.photobucket.com/albums/d...s/IMG_2003.jpg
http://i220.photobucket.com/albums/d...s/IMG_2005.jpg
http://i220.photobucket.com/albums/d...s/IMG_2009.jpg
And i know the fans are on the wrong side of the shroud but thats how i want em lol. :P
Thanks lads!!!!!!
This is a very nice build indeed. Subsribed! I cant wait for the rest of the build.
Very nice job on the psu braiding mate:)
This fans looks :o
Silent? How much V need to start?
Brad ... one of the nicest sleeving jobs I've seen. You definitely are a detail man! Great stuff.
those fans the best of best case fans
there ok on rads two the enermax magma are the best for the rads
this is looking good
They will be on a controller but should be silent once turned down alittle. not sure on voltage.
Thanks dude it took forever. ;)
There more for looks over cooling performance but i cant see them been too bad.
Update 11th May.
Well i finally got around to starting the roof and all i can say is let there be light! I know i suck as i took no pics while doing it but i was been lazy. Basically i used a hole saw bit for each corner and then 4" grinder with 1mm cutting disc to cut the straight parts. Iv cut maybe 1-2mm from the line i marked out that i will file to a crisp edge later. Notice how close the rad is to been too long. Its made for it :)
http://i220.photobucket.com/albums/d...s/IMG_2018.jpg
http://i220.photobucket.com/albums/d...s/IMG_2016.jpg
http://i220.photobucket.com/albums/d...s/IMG_2017.jpg
I kinda messed up on the one corner by using a slightly too big hole saw but once filed down i may run a skim of filler over the edge before it goes off to paint.
Thanks!
oh wow, they ARE nice fans!
looking awesome brad!
Wow looks AMAZING! Can't wait to see how this goes.
