lol each 295 gets its own loop. Spoilt little things they are ;)
LOL yep, total overkill but everything runs nice and cool :)
wow, beautiful build!! Although I think you should try to cool the chipset as well and add a 4th loop :D Anywhere for you to squeeze in a 120.2?
I really like the colors too. Even though the colors aren't exactly as they were supposed to be, it looks fantastic!
thanks, I did think about cooling the chipset, but I would just put that in the CPU loop it think. The only reason I didnt is because I didnt think I was going to keep the motherboard for very long
few updates for you guys :D
hmm, i figure the top pump has the 45s in the wrong direction. you are routing backwards, then forward again...you could just rotate the top res anti-clockwise and use 1 45Quote:
http://www.ollyk.com/cp/newtubing6.jpg
And the good thing is it POSTS !
Many of the eagle eye'd among you will spot something I need to replace. Look at one of the pumps/res
yeah, I need to change setup on that connection. thats not the original problem though. I snapped one of the res clips on the bottom pump/res :(
ah...finally i saw that...haha. i was so engrossed in the looping that i did not notice that. perhaps you should consider these?
http://www.performance-pcs.com/catal...ducts_id=22144
or maybe you could wait for charles to put these sweet res holders up for sale :D
http://www.murderbox.com/uploads/10.mb.009.0900.jpg
they do look good, although for the time being I think I'll just stick to the replacement EK ones !
updated the first post with classified and koolance blocks :D
In those first pics, is the purple fluid actually UV pink? :)
I wasn't eagle eyed, I couldn't see what was wrong with those res's. :(
Wow really nice build. I love the color scheme and pump placement. Well done!
Nice build :up:
what did you use for red coolant ?
thanks !
Its primochill with 2 red Dye Bombs but I'm going to be replacing it with some red primochill tubing and maybe black uv feser :D
Olly ... Beautiful job! I can't believe I missed this one before today. I just can't decide which color scheme I like best - they both look really good. Obviously, the red/white/black looks great with the Classified. Nice job with your pump/res mounts.
This is my new favorite Mountain Mods build!
Thanks Shazza !
To say I studied your build very carefully is an understatement !
I'm glad its your new favorite !
Bravo!!! :clap:
I hope you don't mind if I barrow your reservoir mounting technique... it's just perfect.
Beautiful build!
Very Sweet.
Gorgeous stuff. It's a shame those brackets are custom; I could use some.
Olly,
About that Startech drive backplane..
Have you had any issues with it using the drives you showed?
Thinking about using one of these, but I noticed on Newegg a couple of bad reviews from people who bought one, mainly having to do with saying that Velociraptor and SAS drives don't work in it anymore (something about a new revision).
Was planning on using mainly SSDs in it which seem to work Ok from what I've seen, but a Velociraptor as a storage drive might be nice, but not necessary. Could use a laptop drive like you did instead.
Anyways, just wanted to see what your experience with it has been. Thanks.
Hi mate, I didnt have a problem using the vertex SSD's. Im not even sure a velociraptor would fit even without the 3.5" casing as the drive is thicker than normal 2.5" hard drives. I use a 320gb WD Scorpio black for the 4th drive, and that also fitted perfectly. I bought mine when it first came out so I think im on the 1st revision.
Thanks for the info Olly.
I didn't realize that about the VR. I've got a couple of spare ones down in the ol' basement workshop but I never noticed about it being thicker than normal. Then again I never tried taking it off its sled. I'll go take a look now, thanks for the heads up :up:
That's interesting what you said about getting it when it first came out. Looking at the picture of yours, it has the single set of SATA ports which seems like the current rev. I guess the one people were referring to was this one with the dual sets of ports:
Dual port model
I'm confused by what the hell changed and why, honestly. But whatever, if it works with the SSDs and laptop drives, I'm set.
I got that exact same WD Scorpio drive you have and put it in my wife's MacBook and it's been excellent. Dead quiet and next best thing to an SSD in it, but I didn't want to spring for one of those just for her to surf the Internet and make crap for school with PrintShop ;)
Thanks again, definitely helps.
Mine definately doesnt look like this :
http://c1.neweggimages.com/NeweggIma...998-037-04.jpg
Mine looks like this:
http://www.scan.co.uk/Images/Products/1063030-b.jpg
There is only 4 sata ports on the back, not 8 ! Weird really because at first look I thought that was the same as mine from the front and side !
I got mine from scan, here
The pics are correct but the title does say 8 port......wth ?
