nice to see you aren't killing anymore qx9650s, great results.
Looking good bro, she got more left in her?
EXCELLENT clocks!
I actually found that LN2 was a LOT harder to work with than DICE, especially with this board and its pwm's relatively horrible transient load balancing. a better buck would produce better LN2 results, but for my chip on R2E LN2 brought down the voltage threshold.
For clocking LN2 is relatively useless, if not acually a bit annoying to deal with in this combo. IMO the only place it's helpful is in Vantage; that's some CRAZY swing.
2peakes that's one sick i7 you got there buddy. Keep pushing.:up:
Dude, that is a sick clock on your chip....keep pushin it!!
Very good d-ice results. Looks like that chip will be your friend ;) (and you desreve it after killing all those qx cpus, but one learns as one goes :) )
Given time to tinker, you might get it stable and good for a few screenies at even higher speeds. D-ice seems to be doing really well with the core i7s.
Sorry to hear about your son, and endlessly happy he's ok.
BTW, what happened that he had to go to the ER?
Great Job 2peakes, keep on rocking :up:
So it sound like I can save a little bit of money and wait for the 975 to be released instead of buying a Dewar. I have also had the board shut down on cold bug when I was using an F1E for dice. I let the CPU sit too long and it would shut down. When I tried to power back up I was only getting .5V on the CPU Vcore. I actually increased the Vcore to keep from cold bugging and not because the CPU needed it.
In my area they are not allowed to deliver to residential areas. I have spoken with them and they have a 30l they loan out however they were unsure where it was or what customer had it. I plan on calling them again to see if they located the dewar. One of my biggest issues is the big temp swings with the dry ice. If I could hold a tighter temp range I think I could get even higher.
nice runs... now get to it.... i know you can do better :shocked: :P
I'll bet he's sandbagging a few runs for when others post better results....:up:
