Originally Posted by
Vapor
Updating with three more nozzles now (6.5mm, 5.5mm, 4.5mm) but am removing the Quad Insert data.
Wanted to reinvestigate after getting appreciably higher flowrates than expected (I really really don't think it matches the stock insert for flowrates at a given pumping power)...and also noticed that the nozzle doesn't have the o-ring in it (though I honestly can't recall if it did or not during my tests). I've installed the o-ring and am running again. Getting lower flowrates (good thing, hints that the o-ring was not installed previously) but will have no temp data for a couple days. Will also do the 3.5mm nozzle after this (maybe--might just save it for when I go to i7).
EDIT: okay, new graphs are up :) Again, make what you will of the data...seems to me the single-jet nozzles just don't do much on a dual-die CPU :shrug: The thermal data is basically a wash...
