awesome thank you soo much for the insight for the m32 tweaks, i will have to test those methods soon and hopefully i can get under 7.50.00 run done :toast:
thanks fellas i will keep pushing this chip i hope i can get some nice runs done
That is amazing! Good work! Would you post the settings you used to achieve that BCLK? I can't get my evga past 222.
Edit: I see your eleet voltages, tried them out, still can't get past 222, everything up there is fine, and then past that is immediate freeze/BSOD
- Copy Wazza tweak
- Large system cache , Disable Paging Executive , Clear Page File At Shutdown = 1
- maxmem = 600
- run 16k "x times" until you get ~0.094s and than run 32M
- sometimes ERAM helps
- sub-timings tweaking
- Real Time, Affinity and end explorer
- Well tweaked and lited XP (with Luna (olive green) theme)
outch ok. enough coldbackup and for sure you've got luck with your's.... Mine don't work really good under -80°C so (or the BCLK for this Chip is 209) you've got many luck i think. But for sure, i have a new toy and tomorrow i ordered some Dice for pretests.... I think LN is too hard (sure for my 920 but the other:D, we'll see it):D
well i had a similar problem with my i7 920 when i first started playing with this board, i was able to get my system 3d stable around 223.5 base clock nothing past that would work and the system would just freeze.. but as you can see from the screenshots i took from the tests i've made so far, i started playing with the ioh-vcore and ioh/ich/io and Boom!! i was able to get over 230 base clock with no trouble at all so play with those voltages and see if that helps..also raising the pcie frequency to over 110 helps with overall system stability.
thanks mate for the tips i'll give it a go next time i play around with the board..
i would suggest that you try the ioh-vcore and ioh/ich/io trick that i already talked little about in my earlier posts and see if that helps you get more out from your cpu :up:
Does the above 110 pci-e clock go for all X58 boards or just the Evga one?
yes it did help when i owned dfi x58 board.
small update for the max BCLK...weeeeeee !! :rofl: this is done with the latest bios (E758SZ21).. after testing that bios little today it seems like that atleast memory clocking has improved slightly
http://i163.photobucket.com/albums/t...os/4922mhz.jpg
http://valid.canardpc.com/show_oc.php?id=523738
Very nice result! :up:
I will test my i7 920 under LN2 too, but i think my board is the limit :(
Mikko! I want to see that max bclk Vantage CPU test :D
Amazing result again! Great work bro!:up:
cool i wish you best of luck on that :up: lets hope that everything goes well
hi petri i only have this super hyper fast ati 1650 pro card :rofl: that does not support directX10 so those vantage tests are postponed (again lol) .. maybe if you have some spare cards laying around you could sell me one ? :cool:
http://i163.photobucket.com/albums/t...s/DSCN1519.jpg
thanks mate lol playing with these core i7 boards is making me go insane just small incrementation in clocks is pretty hard and takes alot of tweaking but i guess its always like this when a new generation arrives.
thread update time again.. did some superpi 32 tweaking today. this score entitles me in Hwbot i7 920 category to position 3 soo my goal to get to the top 5 has been now achieved :D
http://i163.photobucket.com/albums/t...os/0742688.jpg
Nicey^^. Whut's that ram? HCF0?
Nice going brother!! Damn nice to see you kickn it in the booty!:D
:up::up:
Wow...nice clocks!
Did "my" tweaks help you?
Congrats :clap:
Mikko.. I have one card for you now :) Drop me e-mail when you have time.
Good 32M!
thanks bro. im sure your too busy with your new toddler and saying to you to bench more would go to blind ears lol
yep they did + doing some of the ones that i already knew before helped me about 8 secs witch imo is not bad at all when were talking about 32M. but there is more work to be done still im sure that if my memory would co operate at 7-7-7-20 at that strap i used with that last test under 7.40.00 would be very possible.
argh petri! your little too late, i already bought a used 295 gtx yesterday soo look out for those max base clock tests in vantage next week, lets hope that 225 - +230 would be possible :up:..
nice result you get there.......amazing with i7 920 :up::up:
thanks guys this chip is not done yet :up: i tortured it today little with the info that i got from shamino i needed to turn on one little thing in bios.
cool im made it to the 5ghz core i7 club :yepp:
http://i163.photobucket.com/albums/t...hotos/5ghz.jpg
i also improved my 32m times sligtly
http://i163.photobucket.com/albums/t...os/0738640.jpg
now do tell what shamino hinted at ? :D
