thanks for sharing, no that I see this, I really wanna get QD's :up:
10mm flow through isn't quite the same as 10mm tubing...much, MUCH more restrictive than a 2in strip of tubing :p:
It's basically a 10mm bore with lots of 'stuff' in the way, heh.
13mm flow through would hopefully alleviate some of the restriction :)
Koolance Dean, do you have any Flow Rate Vs. Pressure Drop charts for your quick disconnect line?
The inner springs are stainless steel.
I don't think we will put a female g14 thread on them but we do have a male g1/4 thread available on both the male and female nozzles. Along with a female/female adapter (ADT-XFF) you could do exactly what you're asking :)
I am picking high number as i said andy.
Of course it will be less, but i like to under promise and over deliver.
Also my entire board and 4 gpu's are fed though that line. :X
On load, my coolant will be about 2C over ambients on the gpu line while running fur mark.
I figure your right about the 1-2C mark, but as i said at start, im picking high numbers here.
Dean, any Flow Rate Vs. Pressure Drop charts for your quick disconnect line?
wait, you can connect those qd to a waterblock? The pictures were confusing. Definately picking one up now. I always thought that it was for drain because i saw no male thread sticking out to screw on to wb.
Unfortunately not, I can see if there are any charts available though! :)
The VL4 line has not had their g1/4 threaded pieces released yet, but VL2 and VL3 do have them available (VL2-MG, VL2-FG and VL3-MG, VL3-FG are their skus). :DQuote:
Originally Posted by Boogerlad
black nickle versions please dean.
:rofl:
your other fittings are black, and your compressions are white. :rofl:
They have made the removal of my cooling system really easy. Thanks to the qd's I can isolate the part of my loop that leaked and fix/test it separately. A grate time saver :up:
yeah gotta love em
in all quick discconects, you need 1 male and 1 female.
i think you need to keep VL3 with VL3's and VL2 with VL2, and also VL4's with VL4s.
i need to change my avatar.... LOL..
you had it first..
I so wish I had QDs. I wanted them, but I couldn't find any when I was on my search. I ended up getting those compression fittings and at slightly over 100 bucks for them, I'm afraid to know what the QDs would run!
I just might get some though, cause I'm really thinking of getting a second loop so my video doesn't have to share. I'll give it a few more months and then see.
Thanks for sharing that info. It will be useful if I do go shopping later. :)
Wisc
QDC ftw :) love 'em
What I did was buy a female that has g1/4 thread and a male one which has a 1/2 barb:
Male - Barb
http://farm4.static.flickr.com/3222/...1e832d4b63.jpg
Female - Thread
http://farm4.static.flickr.com/3110/...00d38277aa.jpg
I bought 2 pairs, so I could put one on each hole on the radiator. Then, when dismantling my loop, the radiator comes of easily :D
100'th post! now 101! :D
BTW, It's true that when you disconnect these, amount of water gets out, but nothing a little intuitiveness with tissue paper can't fix :)
Dean....Do you guys have any 3/8 - 5/8 QD elbows? (possibly rotary)
Great stuff. Thanks 4 posting, NaeKuh. I 've now been considering a change in my upcoming loop for the 4th time. Umph, that makes me really wanting QD for my vidcard... :D
