okay, something more coherent than my earlier "omg! omg!" :D :
I love your mods to the hard drive cage area especially, and your cabling is amazingly clean. I was wondering if you had a pic of the other side of the case with the panel off to show how you did your cable routing. Thanks.
awesome looking build. I like the clashing blue and green colors, and the new hardware is SEXY
Thanks sniper. Ted I don't have pic of the final back panel cable routing right now. Next time I pull the back off I'll take a picture for you. I did however have to jump up and down like packing a suitcase to get it all in place. The main power supply wiring I cut the mesh off and flatened as best I could. Held the rest down with e-tape. The Tagan 1100w came with everything upside down so I ripped the side labels off turned the upside down and mounted the pw supply upside down also. That gave me the wires in the back rather than in the front. I like the combo of the single rad and dual in the top but if I could do it again I would mount a 3x120 in the top and drop the single by the hard drive. It looks cool but I don't like the retriction to flow and the tube routing I've changed twice for the gpu's. A 3x120 off the back and a 3x120 up top would give me better flow, cooling and package space. Those 285's are huge! I plan on buying one more and another EK block as I want TRI-sli before I leap to the i7 board. Building in stages here. I can say the best thing about this build is I can drain, reroute tubing, fill and bleed the system in less than an hour. Here is an ealier pic of the wiring mess in the back.
http://i203.photobucket.com/albums/a...2/DSCN5075.jpg
Thanks, it's really interesting hearing about how that all works together. I'm lookin' forward to seein' the backside of the case after all was said and done, whenever you have a chance to snap a pic. Man, I can believe there had to be some major squishing involved. And, I thought there was something different about that PSU! Very cool idea to turn it all upside down like that.
Tri-SLI sounds tasty!:up:
